Port forwarding on Load balancing
Please i need some assistance.
I have two WAN link which i am load balancing with mikrotik router boad, and i have a radius server with local ip address. I want to be able to reach the radius server outside my network. What do i need to so i can access it from outside?
you can do routing mark for that server (marking by local ip address of that server), and create default route for that marked traffic to go outside through one of your links, and create destination nat → evertything which came on that particular link from outisde by port “xy” forward that traffic to local ip address of the radius server
Hi Mixig,
Thanks so much for your response. Please i will need you to help me with an example of the command on how i will configure it. I would appreciate your quick response.
rgds.
Watch the presentation in my sig, it will explain how to properly configure this.
