Port Forwarding on MikroTik Router.
I have a MicroTik Router that I am trying to troubleshoot. I am just looking to see that ports are setup to forward to a server on the internal network, were they are forwarded to, and how do I configure new port forwarding rules. I have never used one of these routers before and all the gragical tools I have found don’t seem to an functions for this. Please let me know if you can help. Thanks.
This would be a example…
/ip firewall nat add chain=dstnat dst-address=69.69.69.69 protocol=tcp dst-port=5900 action=dst-nat to-addresses=192.168.1.101 to-ports=5900
Culd you show me the command to show the ports that are already set to forward? Thank you very much for your help with this.
/ip firewall nat print
plz tell me what is point to this ip 69.69.69.69 is this my ip from router or you mean external ip ???
thanks alot
“69.69.69.69” here refers to the external ip address on your router
hi dear i read and hear i can port forwording on mikrotik by winbox they said its so easy like this picture in attachment see it plz
do you know that ?
if you know that plz can you tell me how can i do this
thans alot
