port forwarding on pppoE connection
hi everyone im new hear.i would like to get some help on how to port forward on mikrotik router v6.30.4. The router has been fed with a pppoE connection by the isp and i cant access it remotely using internet from another isp.
Port forwarding docs and examples can be found here:
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Port_forwarding_to_internal_FTP_server
About access your MikroTik Router from Internet, it’s possible if you have a public IP address. If not, you can ask your ISP for a port forwarding to your private IP. Otherwise, you can read this
http://forum.mikrotik.com/t/how-to-access-mikrotik-router-configured-with-private-ip-address-in-wan-via-internet/108542/1
are you on public ip. export your firewall filter configuration.
/ip firwall filter export
paste here
I am facing a similar challenge. The router has been fed with a pppoE connection by the isp and i cant access it remotely using internet from another isp
RouterOS 7.8
model = CCR2116-12G-4S+
add action=accept chain=input comment=“"Allow Estab & Related"”
add action=accept chain=input comment=“"Allow VLAN"” in-interface=ADMIN
add action=accept chain=forward comment=“Allow Estab & Related”
add action=drop chain=input comment=Drop
add action=accept chain=forward comment=“"VLAN Internet Access only"”
connection-state=new in-interface=all-vlan out-interface=pppoe-wan
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment=“Link To ISP” out-interface=
pppoe-wan
add action=dst-nat chain=dstnat comment=“Remote Desktop” dst-port=3389
protocol=tcp to-addresses=10.10.10.2 to-ports=3389
