I have just bought MikroTik RB962UiGS-5HacT2HnT and trying to set it up.
I have done all basic configuration and router works well.
Now I am on fine settings.
I nee to setup port forwarding as I have webserver behind router and I want it be accessible from Internet.
Let say external router ip 32.32.32.32 and local webserver ip : 192.168.0.10 and port is 1111 (just an example)
I went to IP->Firewall->NAT and created new NAT Rule:
General:
Chain: dstnat
Protocol: 6 (tcp)
Dst. Port: 1111
In. Interface: ether1-WAN - input internet port
Action:
Action: netmap
To Address: 192.168.0.10
To Ports: 1111
Once the rule was created I am able to access my webserver from Internet : 32.32.32.32:1111
But I got another problem I can not access that webserver from my LAN, I can not access 32.32.32.32:1111 from local host 192.168.0.11.
192.168.0.10:1111 works well but external IP doesn’t work.
Anyone able to help how to resolve the issue? I will be very grateful.
and now I manage to access webserver from outside and insude LAN.
But, as you can see I have to use fixed external router ip 32.32.32.32
But I have dynamic external ip , so the solution will not really work for me.
Anyone can advise how can I modify these 2 scripts for dynamic IP.
In dstnat rule, you can use dst-address-type=local instead of dst-address=32.32.32.32. It does exactly what it says, it will match any address assigned to router.
In case you’d want to use the same port also to access some service on router (e.g. WebFig on 192.168.0.x:80, where x s what router has on LAN interface), add another condition to create exception, i.e. dst-address=!192.168.0.x.
I have to come back to forum as I am facing another small (I hope) problem.
I have finished my port forwarding/hairping NAT setup.
Now I have my FTP server runnig on port 21 on LAN.
The next step is to make Mikrotik internal FTP working.
As port 21 is already taken I am moving it to port 8021.
IP → Services → IP Service List → ftp : 8021
IP → Firewall → Service Poerts ->ftp : 8021
Important question first, do you need FTP server on router for anything? Because it’s not very useful service. It’s not required for normal operation at all. And if you’d want to use it for file sharing with USB disk, it works, but it’s very simple, there’s no good access control, encryptions or anything. And if you already have another FTP server (if I understand it correctly), I don’t see a reason why to deal with this one.
If you really want it, then:
Changing port in IP->Services was correct.
In IP->Firewall->Service Ports->ftp, it’s not clear if you changed the port, of if you added 8021 to existing 21. If you changed it, it’s wrong, because it can affect all FTP connections. This tells router which ports it should inspect for FTP control connections and find related data connections, so that you can allow them in firewall.
If the service is on router itself, it doesn’t need NAT at all, neither dstnat not hairpin. Just allow dst-port=8021 in /ip firewall filter, chain=input and that’s it (assuming you also have standard rule to allow related connections).
I need Mikrotik FTP server as light-weight service to backup main server which is not online 24/7.
I have resolved the problem by removing forwarding and hairpin nat rules as you recommended and disabled firewall rule which was blocking all request from non-LAN.
Order is important, this new accept rule must be before the last drop rule.
If clients use passive move (should be probably default for most of them), you also need rule to accept connections with connection-state=related. Default firewall has such rule (combined with established state).
You need to have your non-standard port in IP->Firewall->Service Ports->ftp (in addition to default 21), otherwise there would be no related connections.
What I find weird is only creating the one rule.
On my current router one made a port forward rule (from incoming interface (specific WAN interface) for specific port(s)/service(s) to a specific LANIP.
Then a separate FW rule to allow same traffic but delineating the Source IP(s) allowed and destination IP for the services coming from the port forwarding rule.
On the Port Forward Rule one could flip ports (incoming on non-standard port for example and flip to standard port).
FW rule would be made for standard port to the specific LANIP.
In microtik its a one shot deal. Just an FYI for those coming from other devices.
PS Order always seems to count!!
