Hello ,
We have a mikrotik that is the main router with a static ip range 80.78.65.x and we have vpn through our network with range 172.16.14.x
Now i need to forward 80.78.65.x:81 to 192.168.0.19:80 , where 192.168.0.19 stand behind 172.168.14.6
i have made some rules my self,
What is the source? Are you trying to send all traffic hitting your WAN IP of 80.78.65.x:81 to 192.168.0.19:80? You want this traffic then directed over the VPN to the 172.168.14.x network? Or are you trying to get internal traffic over to the 192.168.0.19 address?
Are you allowing the source traffic over the VPN? When you torch or run a packet capture where is the last place the traffic is found, i.e. where is it being dropped?
How is the VPN setup in regards to interesting traffic allowed over the VPN? So if router1 can ping and reach the server 192.168.0.19 via port 80, then it has to due with how your VPN is configured.
What about default route on 172.16.14.6 router? Is it 172.16.14.2? If so, both 192.168.0.19 and 172.16.14.6 can’t send reply packets wrong way. So they must get filtered by first or second router. Try to inspect how far the packets get in both directions. Use either Tool->Torch or add some logging rules to prerouting and postrouting chains. On one of those routers, you’ll see packet coming in on one interface and not coming out on other. Check forward chain on this router and make sure that you allow these packets to pass.
i dont understand the VPN part, but it seems very simple to me.
first do the port forwarding (port NATTING) on the router with the public IP address i.e 80.78.65.85. turn it towards 172.16.14.6.
then
do the port forwarding in 172.16.14.6 and turn it towards the DVR i.e 192.168.0.19.
my tip…
in the TAB …General leave the src.address: and dst. address: fields blank and in Action TAB…specify your target address (To address:) and (To ports:)
hope it works.
Regards
