Hello to all, I do know that there are a lot of people that asked the same question, this one I do believe is a little different… I am kind of a newbie on Mikrotik RouterOS and although I did read through the Wiki (tried all the suggestions there) I cant seem to enable either port forwarding or UPNP on my RBL2011 router…
Let me explain the issue in a little more detail:
I am trying to install a new Xclaim Xi1 AP and I want to connect it to its dedicated cloud manager… In order for that to happen I need to port forward ports 443 (TCP) and 123 (UDP) through the NAT/Firewall.. This configuration though should be done for both OUT → IN and IN → OUT.. Sounds easy right???
Well I did follow the manuals on the Wiki (for example http://wiki.mikrotik.com/wiki/Forwarding_a_port_to_an_internal_IP and http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Destination_NAT) I have also tried out the suggestions from established forum posts from other clients that had a similar issue…
Basically what I did was:
- Created port forwarding rules in NAT
- Enabled UPNP (also selected proper external/internal interfaces)
- Also tried playing around with firewall rules
I really do think I messed things up so I decided to factory reset the appliance and start-over from scratch..
Is it possible that someone can at least give me a few points on how I should make the configuration???
