I have problem define port forwarding to open my local PC machine for friends to play steam games through internet.
I have just two PC’s (my game PC and dedicated server for steam game servers (ether2 and 3).
My public internet IP (changed) is 10.10.10.10 (external gateway and DNS is 10.10.10.1) and connected to ether1.
Local IP for server PC is 192.168.88.109
I add this:
add action=dst-nat chain=dstnat dst-address=10.10.10.10 dst-port=3000 protocol=udp to-addresses=192.168.88.109 to-ports=3000
add action=dst-nat chain=dstnat dst-address=10.10.10.10 dst-port=3001 protocol=tcp to-addresses=192.168.88.109 to-ports=3001
add action=dst-nat chain=dstnat dst-address=10.10.10.10 dst-port=“” port=88,500,3074,3544,4500,8777 protocol=udp to-addresses=192.168.88.109
or
add action=dst-nat chain=dstnat dst-address=10.10.10.10 port=88,500,3074,3544,4500,8777 protocol=udp to-addresses=192.168.88.109
But this doesn’t work. I’m even not sure I can use this way if my mikrotik is in ROUTER mode (defined in quick set)
With older DSL modem I just add another rule to port forwarding and everything work fine. Since I moved from ADSL internet provider to new one with RB4011iGS+ on my site, I’m unable understand what i’m doing wrong.
Anyone can point me right direction please?
There is whole configuration export (default router config without modification excemt /nat changes.
# 2024-11-15 15:11:00 by RouterOS 7.16.1
# model = RB4011iGS+
add admin-mac=D4:01:C3:2E:EC:16 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.150-192.168.88.254
/port
set 0 name=serial0
set 1 name=serial1
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge disabled=yes interface=ether1
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add address-pool=dhcp interface=bridge name=defconf
add address=0.0.0.0/24 comment=defconf dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=10.10.10.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=10.10.10.10 port=3074,8777 protocol=tcp to-addresses=192.168.88.109
add action=dst-nat chain=dstnat dst-address=10.10.10.10 dst-port="" port=88,500,3074,3544,4500,8777 protocol=udp to-addresses=192.168.88.109
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
