QOD-port-fwdg
PB750gr3, FW:V:3.35 ) : set as ROUTER mode. and auto connect. (all that works)
wired to 16channel cable modem. and works. and is JUST a model, no wifi here, no AP , no routers of ANY KIND inside the ARRIS(MOT) SB6183
picture 3 parts ARRIS>>> PB750 (New)>> PC — and say 1 foscam we camera the goal not attained.
winbox.exe v6361
ARRIS modem , automatic mode works direct to my PC or to any of 3 other routers on my service shelf, (new or most are no longer supported )
The ARRIS oobe , works great as switch and firewall (routing all that) passed all external tests for exploits wan side.
have noIP working for 5 years, now. no issues. DNS resolves to ,my IP at home. (ISP blocks all ports above 1024 and some below, including 80,and 87 but not all)
most of my browers now block raw IPs or ports or both, but not my beloved (i test bed, Firefox v20 protable)
all works great but the punching a hold in the fire wall and winbox.exe shows no port forwarding pages… oops.. looks like Im in trouble… and am.
the camera is at 10.10.10.191:88 using a fixed IP. (bound /reserved) “foscam-FI9831p”
the camera works local, using Firefoxv20. with URL as IP. (old ff as new one now blocks ID raw, local, ) just for testing I do that.
router base is 10.10.10.100 and DHCP to 199. (span) DNS to 8.8.8.8.
fixed IPs set. for my cam using 750 setups.
even my MKV video server works (local only sure)
All PCs on the gigalan all work and can use internet here at home (2 switches 1glan , distributed all over home) as do all TV(smart) function.
No problems it all works ok, out of box. just need the fire wall (slip through) for port 88.
tried many examples by others. (me googling and reading many here)
tired winbox.exe , nice app.
using that, i clicked IP+firewall + NAT tab.
before masquerade entry (set, out of box default) added these answers for below..
using…winbox.exe I set…
chain = dstnat
src.Address (blank) IDK
dst.address = 10.10.10.191
protocol=6(tcp)
src port, 88
dst.port 88
in. interface=ether1 ?
The web url we used is (NoIPdomain.me:88) for years no problems, I have web page (not at home) that talks to the cam log in as guest and shows live video. ) working for years.
thanks for any help. good day.
