Port Forwarding to Raspberry Pi Wireguard VPN
I have been successfully using a Raspberry Pi as a VPN, configured with Wireguard. The Pi was connected (wired) to a LAN port on a Cisco/Linksys EA3500 Wifi router. This routers WAN was connected to the sole ethernet port of the ISP-provided Hitron cable modem. I had to set up the port forwarding on the Cisco/Linksys router for the Wireguard service. The system worked well, albeit a little slow. For reasons of speed, I chose to replace the Cisco/Linksys wifi router with a Mikrotik hEX RB750Gr3 router. I was unprepared for the flexibility and programming options the Mikrotik offered. For example, the port forwarding in the Cisco/Linksys wifi router was simple: select the IP address of the Pi and set the desired port to forward. The Mikrotik router apparently needs to be set up with Firewall NAT and Filter rules. As a complete noob, I have been searching through this forum and found a couple of topics that seem related:
  1. Help port forwarding with Raspberry Pi OpenVPN PiVPN - #5 by successfulnothing
  2. Pivpn wireguard portforwarding problem
The current Filter rules for my Mikrotik are:
[code]
action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related
action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
[//code]
Current NAT rules are:
[code]
action=dst-nat chain=dstnat dst-address= dst-port=51820 protocol=udp to-addresses= to-ports=51820
[//code]
I still cannot contact the VPN outside of the LAN (nor inside, either). Have I misconfigured something? Are there filter/NAT rules that need to be added, changed, or removed? I would certainly appreciate an experience eye. Thank you in advance!
chain=dstnat action=dst-nat to-addresses=$RPI_IP to-ports=51820 protocol=udp in-interface-list=WAN dst-port=51820
eventually replace in-interface-list= with in-interface=
Have you considered running the wireguard on the hex instead?
oops my bad you didnt buy the ARM version, hex refresh for the same price.
I am running successful WireGard on my RB750Gr3, and also was running on my old RB750GL, before I swap.
These devices is MIPS. Maybe you think of the BTH thats only what I think is supported with ARM and up.
Here my guide how I set it up:
I have considered using Wireguard with the Mikrotik router. Since the Wireguard service had already been successfully deployed on the RPi my first choice was to continue using the Pi. I will look into how to configure the Mikrotik Wireguard service. Thanks.
Thank you. I will try this.
Ahh correct I was thinking about BTH, much thanks!
I don't know why it's only ARM and Tile, do you know or somebody else in this great forum ?
Is it because of that's running some P2P service, that can't be compiled to ARM and Tile ?
I think it's Wireguard as VPN service with a P2P wrapper.
I haven't seen any config of BTH, so don't know.
It obviously doesn't contain special sauce that can't be compiled on other platforms.
I think (suspect, infer, intuit, guess) that it has more to do with Mikrotik providing free relays, and therefore not making it available for older and non-router platforms. Arm/Tile pretty much achieves that.
