Port forwarding troubles
I have a MikroTik with port forwarding to a VNC server on the LAN-side working using NAT dstnat. However, port forwarding is not working to a LAN-side device running an SSH server and Web server. Here’s the MikroTik NAT config:
add action=dst-nat chain=dstnat comment="VNC Server" dst-address=\
    10.199.6.39 dst-port=5900 protocol=tcp to-addresses=10.1.10.11 to-ports=\
    5900
add action=dst-nat chain=dstnat dst-address=10.199.6.39 dst-port=5800 \
    protocol=tcp to-addresses=10.1.10.11 to-ports=5800
add action=dst-nat chain=dstnat dst-address=\
    10.199.6.39 dst-port=222 protocol=tcp to-addresses=10.1.5.101 to-ports=22
add action=dst-nat chain=dstnat dst-address=10.199.6.39 dst-port=5101 \
    in-interface=PC_LAN protocol=tcp to-addresses=10.1.5.101 to-ports=5101
FWIW, there are several VLANs configured (Servers, PCs, Printers & VOIP Phones). 10.1.10.11 is a PC with a DHCP address provided by the MikroTik. 10.1.5.101 is a Server and it’s IP is set statically on the device. The MikroTik WAN IP address is 10.199.6.39. It is also the gateway for each of the VLANS. If I try to ping 10.1.5.101 from the MikroTik, no response.
How can I resolve this problem? Thank you.
(1) This half rule needs to be removed it serves no purpose…
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=dst-nat chain=dstnat comment=“VNC Server” dst-address=
5900
(2) This looks not correct… Why did you add in-interface???
What does your firewall rule look like for port forwarding??
Thanks for the reply. In the course researching how to configure and troubleshoot the MT firewall, additions 1 & 2 were suggested. I’ve just removed them. Re: “What does your firewall rule look like for port forwarding??”
Here are the firewall filter rules:
    established,related,untracked
    invalid
    in-interface-list=!LAN
add action=accept chain=forward connection-state=established,related,new \
    in-interface=PC_LAN out-interface=Server_LAN
add action=accept chain=forward dst-address=192.168.88.241 src-address=\
    10.1.10.0/24
add action=accept chain=input dst-port=80 protocol=tcp src-address=\
    10.1.10.0/24
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=forward comment="Allow port forwarding" \
    connection-nat-state=dstnat
In the forward chain you have these two rules now.
add action=accept chain=forward comment=“Allow port forwarding”
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
Get rid of the second rule its redundant and provides a bit of security,
Much better is the following (in order)
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN {assuming you want internet access}
add action=drop chain=forward comment=“drop all else”
Furthermore suggesting these are to be reviewed.
10.1.10.0/24
10.1.10.0/24
(1) What is the purpose of this rule???
If you want A LAN to have access to another LAN it would go here… format and order…
add action=accept chain=forward [ from interface A ] to [ interface B ]
where it could be by interface name or subnet etc…
add action=accept chain=forward in-interface=interfacenameX out-interface=interfacenameY
or
add action=accept chain=forward src-address=192.168.xx.0/24 dst-address=192.168.yy.0/24
(2) This rule seems okay just place it also before the drop rule…
add action=accept chain=forward dst-address=192.168.88.241/32 src-address=
10.1.10.0/24
(3) This rule I dont understand the purpose??
10.1.10.0/24[/i]
This rule is intended to let a PC on the VLAN called “PC_LAN” access a server on the VLAN called “Server_LAN”. Does this look better, getting rid of the connection-state?
add action=accept chain=forward in-interface=PC_LAN out-interface=Server_LAN
10.1.10.0/24
I just disabled this. 192.168.88.241 is the dhcp address of a smart switch connected to the MicroTik.
10.1.10.0/24
This allows me to access the MikroTik in a browser from any PC in the LAN. I’ll disable this when everything is working.
It seems odd that port forwarding dst-nat for VNC to a machine on PC_LAN is working but port forwarding to a machine on Server_LAN for SSH and HTTP are not working. I cannot even ping the machine on the Server_LAN from the MikroTik device, even after adding a rule like this:
add action=accept chain=forward src-address=192.168.88.0/24 dst-address=10.1.5.0/24
Is it because the IP addresses are not DHCP addresses assigned by the MikroTik?
As stated would like to see a network diagram to see relationship of devices.
Need FULL export of config (just ensure any public IPs are hidden).
Here’s a link to a network diagram: https://drive.google.com/file/d/1KlfzfKHk5lBpBk5AusM89uimk0b_VJQG/view?usp=sharing
I’ll get you the full config file. I’ve lost remote access for now, so I have to go in and fix that. Tomorrow.
Thanks.
Thanks for your patience. Here’s the current rsc file:
# jul/11/2022 13:59:49 by RouterOS 6.49.6
# software id = BFI3-972K
# model = RB750Gr3
# serial number = D5030F24F9A6
add admin-mac=DC:2C:6E:B7:2F:E7 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=LAN_Port
/interface vlan
add interface=LAN_Port name=PC_LAN vlan-id=10
add interface=LAN_Port name=Print_LAN vlan-id=30
add interface=LAN_Port name=Server_LAN vlan-id=5
add interface=LAN_Port name=VOIP_LAN vlan-id=20
set 0 default-vlan-id=0 vlan-mode=disabled
set 1 default-vlan-id=0 vlan-mode=disabled
set 2 default-vlan-id=0 vlan-mode=disabled
set 3 default-vlan-id=0 vlan-mode=disabled
set 4 default-vlan-id=0 vlan-mode=disabled
set 5 default-vlan-id=0 vlan-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Printer_LAN_Pool ranges=172.16.30.50-172.16.30.99
add name=VOIP_LAN_Pool ranges=192.168.20.50-192.168.20.99
add name=PC_LAN_Pool ranges=10.1.10.50-10.1.10.99
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=Printer_LAN_Pool disabled=no interface=Print_LAN name=\
    Print_DHCP
add address-pool=VOIP_LAN_Pool disabled=no interface=VOIP_LAN name=VOIP_DHCP
add address-pool=PC_LAN_Pool disabled=no interface=PC_LAN name=PC_DHCP
add bridge=bridge comment=defconf interface=LAN_Port
set discover-interface-list=all
/interface ethernet switch host
add mac-address=B8:CA:3A:91:3A:85 ports=LAN_Port share-vlan-learned=no \
    switch=switch1 vlan-id=0
    192.168.88.0
add address=10.1.10.1/24 interface=PC_LAN network=10.1.10.0
add address=192.168.20.1/24 interface=VOIP_LAN network=192.168.20.0
add address=172.16.30.1/24 interface=Print_LAN network=172.16.30.0
add address=10.1.5.1/24 interface=Server_LAN network=10.1.5.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.20.99 client-id=1:10:bd:18:ae:55:6e mac-address=\
    10:BD:18:AE:55:6E server=VOIP_DHCP
add address=172.16.30.50 client-id=1:9c:ae:d3:ea:85:56 mac-address=\
    9C:AE:D3:EA:85:56 server=Print_DHCP
add address=192.168.88.241 client-id=1:78:45:58:fd:d1:52 comment="Switch1" \
    mac-address=78:45:58:FD:D1:52 server=defconf
add address=172.16.30.52 client-id=1:48:ba:4e:3a:4:38 mac-address=\
    48:BA:4E:3A:04:38 server=Print_DHCP
add address=192.168.20.98 client-id=1:a4:93:4c:fe:ef:b mac-address=\
    A4:93:4C:FE:EF:0B server=VOIP_DHCP
add address=192.168.20.97 client-id=1:a4:93:4c:fe:ee:f8 mac-address=\
    A4:93:4C:FE:EE:F8 server=VOIP_DHCP
add address=192.168.20.96 client-id=1:e8:ed:f3:6b:6:9c mac-address=\
    E8:ED:F3:6B:06:9C server=VOIP_DHCP
add address=192.168.20.95 client-id=1:e0:2f:6d:60:4c:6b mac-address=\
    E0:2F:6D:60:4C:6B server=VOIP_DHCP
add address=192.168.20.94 client-id=1:e0:2f:6d:60:4c:10 mac-address=\
    E0:2F:6D:60:4C:10 server=VOIP_DHCP
add address=192.168.20.93 client-id=1:e0:2f:6d:60:4b:e7 mac-address=\
    E0:2F:6D:60:4B:E7 server=VOIP_DHCP
add address=192.168.20.92 client-id=1:a4:93:4c:fe:f3:55 mac-address=\
    A4:93:4C:FE:F3:55 server=VOIP_DHCP
add address=10.1.10.0/24 dns-server=10.199.6.6 domain=solv.local gateway=\
    10.1.10.1 wins-server=10.199.6.6
add address=172.16.30.0/24 dns-server=10.199.6.6 domain=solv.local gateway=\
    172.16.30.1 wins-server=10.199.6.6
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    invalid
add action=accept chain=forward dst-address=10.1.5.101 src-address=\
    192.168.88.0/24
add action=accept chain=forward dst-address=10.199.6.0/24 src-address=\
    192.168.88.0/24
    out-interface=PC_LAN src-address=10.199.6.6
    out-interface=Server_LAN src-address=10.199.6.6
add action=accept chain=forward dst-address=10.1.5.0/24 src-address=\
    192.168.88.0/24
    dst-address=192.168.88.0/24 dst-port=20-65535 out-interface-list=LAN \
    protocol=tcp src-address=10.199.6.6
    protocol=udp src-address=10.199.6.6
    dst-address=10.199.6.6 dst-port=20-65535 in-interface-list=LAN \
    out-interface-list=LAN protocol=tcp src-address=192.168.88.0/24
    out-interface-list=LAN protocol=udp src-address=192.168.88.0/24
    dst-address=192.168.88.0/24 out-interface-list=LAN src-address=10.199.6.6
    10.1.10.0/24
    10.1.10.0/24
    established,related,new,untracked
    connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=9100 \
    protocol=tcp src-address=10.1.10.0/24
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=161 \
    protocol=udp src-address=10.1.10.0/24
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=3289 \
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=515 \
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=3702 \
add action=accept chain=forward dst-address=10.1.10.0/24 dst-port=2968 \
    protocol=tcp src-address=172.16.30.0/24
add action=accept chain=forward dst-address=172.16.30.0/24 dst-port=2968 \
add action=accept chain=forward dst-address=10.1.10.0/24 dst-port=445 \
add action=drop chain=forward comment="Drop all else"
add action=masquerade chain=srcnat disabled=yes
add action=dst-nat chain=dstnat comment="VNC to PC" dst-address=\
    5900
add action=dst-nat chain=dstnat comment="Rsync backup" dst-address=\
add action=dst-nat chain=dstnat comment="HTTP to WS" dst-address=10.199.6.39 \
    dst-port=81 protocol=tcp to-addresses=10.1.5.100 to-ports=81
add action=dst-nat chain=dstnat dst-address=10.199.6.39 dst-port=82 protocol=\
    tcp to-addresses=10.1.5.99 to-ports=81
add action=dst-nat chain=dstnat comment="RDP to Hyper-V Host " dst-address=\
    10.199.6.39 dst-port=3389 protocol=tcp to-addresses=10.1.5.91 to-ports=\
    3389
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
Comments:
(1) Missing entry, once all is complete.
add admin-mac= auto-mac=no comment=defconf name=bridge vlan-filtering=yes
(2) Assign vlans to the bridge…
/interface vlan
add interface**=bridge** name=PC_LAN vlan-id=10
add interface=bridge name=Print_LAN vlan-id=30
add interface=bridge name=Server_LAN vlan-id=5
add interface**=bridge** name=VOIP_LAN vlan-id=20
(3) Why does the Server vlan “5” not have any other definitions.
(4) Get rid of the apples and oranges, if you want a subnet use a vlan.
Thus bridge subnet, should be changed to a vlan
/interface vlan
add interface**=bridge** name=88_LAN vlan-id=88
(5) Where is IP pool, DHCP server, DHCP server network for Server_LAN ??
(6) Clean up Bridge port settings… now having ether2 ( or LAN-PORT) on bridge makes more sense,…
add bridge=bridge comment=defconf interface=LAN_Port ingress-filtering=yes frame-type=admit-only-vlan-tagged
add bridge=bridge comment=defconf interface=ether3 pvid=88 ingress-filtering=yes frame-type=admit-priority-and-untagged
add bridge=bridge comment=defconf interface=ether4 pvid=88 ingress-filtering=yes frame-type=admit-priority-and-untagged
add bridge=bridge comment=defconf interface=ether5 pvid=88 ingress-filtering=yes frame-type=admit-priority-and-untagged
(7) This should be set to the management INTERFACE LIST or in other words, the one time a single SUBNET is identified as and interface list entry - which all your managed devices get their IP address from!!!
set discover-interface-list=Manage
Where
add name=Manage
/interface list members
add interface=88_LAN list=Manage
OVERALL needs to change to this…
add interface=Server_LAN list=LAN
add interface=PC_LAN list=LAN
add interface=VOIP_LAN list=LAN
add interface=Print_LAN list=LAN
add interface=88_LAN list=LAN
(8) This MISSING knowledge, your network diagram Failed to show me what IP address the switch has !!!
I will assume its the former bridge lanip structure so now our vlan88
Thus things get a tad complicated only because of unifi products.
Case A - unifi switch is like any other and thus its management vlan comes in tagged as per a proper TRUNK port. No change to bridge port settings required.
Case B - unifi switch expects the management vlan as untagged if so the Bridge ports above have to be modified as such to recognize that ether2 would have to be a HYBRID port.
add bridge=bridge comment=defconf interface=LAN_Port pvid=88
(9) MISSING, Bridge vlan interface settings to match
Case A (ether2 is trunk)
/interface bridge vlan
add bridge=bridge tagged=bridge,LAN_Port untagged=ether3,ether4,ether5 vlan-ids=88
add bridge=bridge tagged=bridge,LAN_Port vlan-ids=5
add bridge=bridge tagged=bridge,LAN_Port vlan-ids=10
add bridge=bridge tagged=bridge,LAN_Port vlan-ids=20
add bridge=bridge tagged=bridge,LAN_Port vlan-ids=30
Of course this could be shortened to
add bridge=bridge tagged=bridge,LAN_Port vlan-ids=5,10,20,30
CASE B (ether2 is hybrid)
add bridge=bridge tagged=bridge untagged=LAN_Port,ether3,ether4,ether5 vlan-ids=88
(10) Dont know what you are doing here, but its not standard on a hex… suggest not using it.
(11) Modify IP address to match above and also missing definition of vlan5 here as well!
add address=192.168.88.1/24 comment=defconf interface=88_LAN network=
192.168.88.0
(12) In terms of firewall rules. Input chain is SAFE but not optimal… It depends if you want access to the router to be minimized to just the admin or not.
Thats up to you to decide.
(13) For the forward chain
a. the order is out of whack. below is fixed!!
b. Also any mention of new etc… is redundant and not required / removed
This rule is now redundant and should have been removed…
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
++++++++++++++++++++++++++++++++++++++++++++++ above are basic default rules that should start the chain
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN { good! = to allow internet access by all LAN members}
Rest are partially okay but I see issues… one by one…
This is a better example of format but lets look at your logic…
192.168.88.0/24
192.168.88.0/24
192.168.88.0/24
First of all the last rule Already includes the first rule!!!
The second rule is weird, you are allowing access to your own router which is an input chain rule.
I will have to think about the validity of this second rule…
Something seriously wrong with these including OVERLAP anything with the 10.199.6.6
THE FORWARD CHAIN is NOT for PORT FORWARDING.
You have External IPs that are attempting access to the MT device…
The best solution is on the MAIN ROUTER to create routes that point to the subnets and associate them with the WANIP of the MT device as the solution.
Then these rules should make sense… as its more of a LAN to LAN type allowance…
Right now there is no way for the main router to reach the mT device if people are looking for 192.168.88.0 its traffic the main router will just drop.
Example of this type of rule…
add action=accept chain=forward dst-address=192.168.88.0/24 out-interface-list=LAN
I will have to think about this as well. :frowning:
Overall, I would try to simplify your rulesets and make sense of them, they are all over the place.
Try to find common themes by grouping use cases together.
It may be useful to use firewall address lists and interfaces to reduce the number of rules.
There certainly is duplication that can be avoided and that stems from poor requirements planning…
(14) DESTINATION NAT…
Didnt find too much off here. I dont know why you have RDP in the mix, thats usually a security nightmare that attracts unwanted attention. Is there anyway to avoid that like use wireguard vpn instead LOL.
This rule - get rid of the in-interface not helpful…
(15) If you have users using the WANIP to access servers (vice direct LANIP) and the server is within the same subnet as the user you will run into hairpin nat issues, but I dont know if that is the case.
(16) Set to none, its not a secure access method
/tool mac-server
set allowed-interface-list=NONE
(17) Set to management interface…
set allowed-interface-list=Manage
All the servers are configured with static IPs. Should I configure the servers with DHCP and make them static on the MikroTik?
The IP of the Unifi switch is 192.168.88.241 (DHCP). It’s connected to the LAN port of the Mikrotik from a Trunk port on the Unifi.
Okay so it sounds like Case A and a trunk port is good!
I typically either let the MT select it and then make it static or enter the IP of a device manually to the MT leases with mac address.
Either way…do whats easiest.
Servers should be on their respective subnet, I am talking about the managed device itself and it seems the switch is on the correct management subnet already.
Your command, add bridge=bridge comment=defconf interface=ether3 pvid=88 ingress-filtering=yes frame-type=admit-priority-and-untagged and the like should(?) be add bridge=bridge comment=defconf interface=ether3 pvid=88 ingress-filtering=yes frame-types=admit-only-untagged and priority. However, the result is “failure: device already added as bridge port
Same goes for all the other “add bridge=bridge…” commands.
ANAV - Thanks for all your help. I’m done for today. I’ll report back tomorrow.
As they say, one bridge at a time! :slight_smile:
You will get there, will take some patience and perseverance.
I lost remote access to my 88_LAN machine, so I had to go on-site. I have total(?) access to the Internet from PC_LAN and VOIP_LAN. I have limited access to the internet from 88_LAN. For example, when I go to https://community.ui.com/ from my machine on 88_LAN, it hangs loading fonts from google and ends with a “Fetch” error. No such issue getting ui.com from PC_LAN.
I still have no access to a machine on the Server_LAN. I can only ping 10.1.5.1 and not 10.1.5.101 for example. I must have a problem with the switch config.
AFAIK, this line is baked in. I cannot find where/how to delete it: /interface ethernet switch host
Here’s the current config file.
# jul/12/2022 11:16:50 by RouterOS 6.49.6
# model = RB750Gr3
/interface vlan
add interface=bridge name=88_LAN vlan-id=88
add interface=bridge name=PC_LAN vlan-id=10
add interface=bridge name=VOIP_LAN vlan-id=20
add name=Manage
    Print_DHCP
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
    ingress-filtering=yes interface=LAN_Port
add bridge=bridge comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=\
    ether3 pvid=88
    ether4 pvid=88
    ether5 pvid=88
add bridge=bridge tagged=bridge,LAN_Port untagged=ether3,ether4,ether5 \
    vlan-ids=88
    192.168.88.0
add address=192.168.88.1/24 comment=defconf interface=88_LAN network=\
    192.168.88.0
/ip dhcp-client
add address=192.168.88.241 client-id=1:78:45:58:fd:d1:52 comment=" Uni1" \
add address=10.1.10.0/24 dns-server=10.199.6.6 domain=ABC.local gateway=\
add address=172.16.30.0/24 dns-server=10.199.6.6 domain=ABC.local gateway=\
    192.168.88.1
/ip dns static
    invalid
    10.1.10.0/24
    10.1.10.0/24
    192.168.88.0/24
    192.168.88.0/24
    192.168.88.0/24
    10.1.10.0/24
    connection-nat-state=dstnat disabled=yes
add action=dst-nat chain=dstnat comment="VNC to GIS PC" dst-address=\
    5900
add action=dst-nat chain=dstnat comment="HTTP to WTS" dst-address=10.199.6.39 \
    3389
/system clock
/tool mac-server
(1a) First thing you need to REMOVE THE DUPLICATE IP ADDRESS!!!
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
192.168.88.0
{ the correct one }
(1b) Second thing is you are missing the all important vlan-filtering=yes on the /interface bridge. This might clear up most issues!!
(2) You still have not solved the mystery of vlan5, does it exist? No IP address, NO DHCP server etc…
(3) Remove the bridge entry, the VLAN are the required interfaces to identify!
(4) What is the purpose of this rule?
10.1.10.0/24
  • I fixed #1 a &b and #3 per your suggestions.
  • Re #2, I added IP Address, DHCP server, and Pool for Server_LAN.
  • Re #4, the rule allows me to access the GUI of the MikroTik from the machine I’m VNC’d to at the moment.
Still not able to ping 10.1.5.101 from PC_LAN. Still not able to connect remotely to a machine on 88_LAN (instead I am VNC’d to the machine on PC_LAN). Here’s the current config file.
# jul/12/2022 12:50:07 by RouterOS 6.49.6
# model = RB750Gr3
add admin-mac=DC:2C:6E:B7:2F:E7 auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add name=Manage
add name=Server_LAN_Pool ranges=10.1.5.50-10.1.5.59
    Print_DHCP
add address-pool=Server_LAN_Pool disabled=no interface=Server_LAN name=\
    Server_DHCP
    ether3 pvid=88
    ether4 pvid=88
    ether5 pvid=88
    vlan-ids=88
    192.168.88.0
/ip dhcp-client
add address=192.168.88.241 client-id=1:78:45:58:fd:d1:52 comment="ABC Uni1" \
    192.168.88.1
/ip dns static
    invalid
    10.1.10.0/24
    10.1.10.0/24
    192.168.88.0/24
    192.168.88.0/24
    192.168.88.0/24
    10.1.10.0/24
    5900
add action=dst-nat chain=dstnat comment="RDP to WTS-VMs Host " dst-address=\
    3389
/system clock
/tool mac-server
Eventually we want that to be Manage, but lets wait until we solve the issues at hand.
Where are you trying to access the MT device from?
One of the MT subnets?
A device behind the MAIN router but not behind the MT?
other??
You should be able to use winbox and not have to use any webgui etc…
