horizn
1
As described here https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT I’ve created a rule to forward external port 65000 onto 192.168.1.4 port 65000:
/ip firewall nat add chain=dstnat dst-port=65000 action=dst-nat protocol=tcp to-address=192.168.1.4 to-port=65000
once that is done I can’t establish outgoing connection to any host to port 65000 from my local network anymore.
horizn
2
it worked when I’ve configured my WAN ip as dst-address, so this Wiki needs updating…
Znevna
3
The wiki and the manual mentioned are fine, you just need to parse them properly.
“You forgot to hook up the doll.”
You didn’t use an interface or dst-address.
Ergo, your rule grabbed any connection to 6500 and routed it locally.
