Good evening,
I recently purchased my first routerboard, an RB2011UiAS-RM, and am very pleased with it except for one challenge that I haven’t been able to resolve. Please forgive me if I’ve overlooked something obvious.
I’m replacing a router running DD-WRT that performs very poorly, but as I’m trying to avoid disrupting services, I’ve placed the MikroTik in front of the existing router (between it and the cable modem), double-NATing everything on the existing network. The existing router is hosting the 192.168.0.0/24 subnet and I’m moving to the 10.0.0.0/16 subnet on the MikroTik. The WAN interface of the existing router is assigned the 10.0.0.37 address on the MikroTik.
I have several servers behind the previous router to which I forward several ports. I was able to move all but one of these servers onto the 10.0.0.0/16 subnet hosted by the MikroTik and configure the port forwards to point to their new addresses and all is well.
When I try to configure the last server similarly, however, I am unable to access the services on the destination server from the Internet. This server is a Cent OS 6 server that is dual homed on both the old (192.168.0.10) and new (10.0.0.11) subnets. This server exposes SSH (22) and HTTP (80) to the Internet.
I can access the services by connecting to both the old and new IP from their respective networks. That is, I can connect to the services at 10.0.0.11 when connected to the 10.0.0.0/16 network, and I can connect to the 192.168.0.10 services when connected to the 192.168.0.0/24 network. I can even access the 10.0.0.11 services when connected to the 192.168.0.0/24 network.
I can configure port forwarding on the existing DD-WRT router to forward to the 192.168.0.10 address and configure the MikroTik to forward the ports for the outside world to the existing router’s IP (10.0.0.37), and the services function as expected. Using Steve Gibson’s Sheilds Up! tool, these ports are listed as “Open”.
If, however, I configure the MikroTik to forward to the 10.0.0.11 address directly, the services are completely inaccessible to the Internet. Using Steve Gibson’s Shields Up! tool, these ports are listed as “Stealth”.
I have verified this behavior by switching amongst both configurations. Services accessible when doubly-forwarded, inaccessible when only traversing the MikroTik. The behavior is completely consistent.
My forwarding rules in the working configuration appear as follows:
[user@MikroTik] > /ip firewall nat print detail
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=ether1-gateway log=no log-prefix=""
1 chain=dstnat action=dst-nat to-addresses=10.0.0.37 to-ports=80 protocol=tcp
in-interface=ether1-gateway dst-port=80 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=10.0.1.1 to-ports=443 protocol=tcp
in-interface=ether1-gateway dst-port=443 log=no log-prefix=""
3 chain=dstnat action=dst-nat to-addresses=10.0.0.37 to-ports=22 protocol=tcp
in-interface=ether1-gateway dst-port=22 log=no log-prefix=""
And in the non-working configuration:
1 chain=dstnat action=dst-nat to-addresses=10.0.0.11 to-ports=80 protocol=tcp
3 chain=dstnat action=dst-nat to-addresses=10.0.0.11 to-ports=22 protocol=tcp
What I’ve Done:
- My initial thought was that the system firewall on the problematic server was blocking access on that subnet, but this does not appear to be the case as I can access the services from the local network. A visual inspection of the iptables rules does not indicate anything out of place to me. Also, completely disabling the firewall temporarily has no effect.
The iptables rules appear as follows:
# Firewall configuration maintained by puppet.
# Manual customization of this file is not recommended.
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
# SSH
-A INPUT -p tcp -m state --state NEW -m tcp --dport 22 -j ACCEPT
# NTP
-A INPUT -p udp -m state --state NEW --dport 123 -j ACCEPT
# DNS
-A INPUT -p udp -m state --state NEW --dport 53 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 53 -j ACCEPT
# LDAP
-A INPUT -p tcp -m state --state NEW --dport 389 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 636 -j ACCEPT
# Kerberos
-A INPUT -p tcp -m state --state NEW --dport 88 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 749 -j ACCEPT
# NFS
-A INPUT -p tcp -m state --state NEW --dport 111 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 111 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 2049 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 2049 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 32803 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 32769 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 892 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 892 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 875 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 875 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 662 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 662 -j ACCEPT
# Samba
-A INPUT -p tcp -m state --state NEW --dport 137 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 138 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 139 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 445 -j ACCEPT
# mDNS
-A INPUT -p udp -m state --state NEW --dport 5353 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 5353 -j ACCEPT
-A INPUT -p udp -m state --state NEW --dport 5354 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 5354 -j ACCEPT
# HTTP
-A INPUT -p tcp -m state --state NEW --dport 80 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 443 -j ACCEPT
# Puppet
-A INPUT -p tcp -m state --state NEW --dport 8140 -j ACCEPT
## MySQL
-A INPUT -p tcp -m state --state NEW --dport 3306 -s 10.0.1.2 -j ACCEPT
## Reverse SSH Tunnels
-A INPUT -p tcp -m state --state NEW --dport 3001 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 4201 -j ACCEPT
-A INPUT -p tcp -m state --state NEW --dport 31337 -j ACCEPT
# Default
-A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -j REJECT --reject-with icmp-host-prohibited
-A FORWARD -j REJECT --reject-with icmp-host-prohibited
COMMIT
- I have confirmed that the services are listening on both interfaces.
$ sudo netstat -tunelp | grep -E ':22|:80 '
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 111935568 2265/sshd
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 20671 2973/nginx
tcp 0 0 :::22 :::* LISTEN 0 111935570 2265/sshd
- I have also confirmed that I can forward the same services to another host and they function. This host is running debian stable.
1 chain=dstnat action=dst-nat to-addresses=10.0.1.1 to-ports=80 protocol=tcp
3 chain=dstnat action=dst-nat to-addresses=10.0.1.1 to-ports=22 protocol=tcp
All this leads me to believe that there is something strange that the MikroTik is doing to the forwarded packets that is causing them to be rejected by the CentOS box. I’ve been banging my head on this for three days and am completely stumped. This is the last hold up to getting rid of the double NAT configuration and routing all of my traffic through the MikroTik.
Sorry for the long post. Any ideas?
