Hi all.
I try to forward 80 port to internal server.
For start I tried this command:
ip firewall nat add chain=dstnat dst-address=xx.xx.xx.xx protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.29 to-ports=80
but it’s not work.
After that i tried to add rule use winbox:
but it’s not work too.
Firewall rules:
[admin@MikroTik] > /ip firewall export
# oct/28/2017 10:01:44 by RouterOS 6.35
# software id = 356A-NAW9
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=beeline src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface=ether1-gateway src-address=192.168.1.0/24
add action=netmap chain=dstnat dst-port=3389 in-interface=beeline protocol=tcp to-addresses=192.168.1.12 to-ports=3389
add action=netmap chain=dstnat dst-port=3389 in-interface=beeline protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.12 to-ports=3389
add chain=srcnat
add action=src-nat chain=srcnat dst-address=192.168.1.12 dst-port=3389 protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.1
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.xxx dst-port=80 protocol=tcp to-addresses=192.168.1.29 to-ports=80
For interface version:
add chain=srcnat
add action=netmap chain=dstnat in-interface=beeline dst-port=80 protocol=tcp to-addresses=192.168.1.29 to-ports=80
RDP is working fine. Http is not working.
why is this happening? What am I doing wrong?
