I changed to port 7878 to see if something was restricting 81.
Some logging:
Test dstnat: in:ether1-gateway out:(unknown 0), src-mac ac:84:c9:f9:80:60, proto TCP (SYN), 24.114.62.198:57701->192.168.2.15:7878, len 60
Filter forward: in:ether1-gateway out:bridge-local, src-mac ac:84:c9:f9:80:60, proto TCP (SYN), 24.114.62.198:57677->192.168.88.50:7878, NAT 24.114.62.198:57677->(192.168.2.15:7878->192.168.88.50:7878), len 60
Export of config:
nov/29/2019 18:59:05 by RouterOS 6.45.7
software id = I0Y9-ZE69
model = 2011UiAS-2HnD
serial number = 467404E11DAA
add admin-mac=4C:5E:0C:32:B4:9E auto-mac=no fast-forward=no mtu=1500 name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether6-master-local
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether7-slave-local
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether8-slave-local
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether9-slave-local
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether10-slave-local
set [ find default-name=sfp1 ] name=sfp1-gateway
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce distance=indoors mode=ap-bridge ssid=NSHome wireless-protocol=802.11
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=Stormwatch342 wpa2-pre-shared-key=Stormwatch342
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.30-192.168.88.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local name=default
/user group
add name=sniffer policy=ssh,read,!local,!telnet,!ftp,!reboot,!write,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether7-slave-local
add bridge=bridge-local interface=ether8-slave-local
add bridge=bridge-local interface=ether9-slave-local
add bridge=bridge-local interface=ether10-slave-local
set discover-interface-list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master-local list=discover
add interface=ether7-slave-local list=discover
add interface=ether8-slave-local list=discover
add interface=ether9-slave-local list=discover
add interface=ether10-slave-local list=discover
add interface=wlan1 list=discover
add interface=bridge-local list=discover
add interface=ether2 list=mactel
add interface=ether3 list=mactel
add interface=ether2 list=mac-winbox
add interface=ether4 list=mactel
add interface=ether3 list=mac-winbox
add interface=ether5 list=mactel
add interface=ether4 list=mac-winbox
add interface=ether6-master-local list=mactel
add interface=ether5 list=mac-winbox
add interface=ether7-slave-local list=mactel
add interface=ether6-master-local list=mac-winbox
add interface=ether8-slave-local list=mactel
add interface=ether7-slave-local list=mac-winbox
add interface=ether9-slave-local list=mactel
add interface=ether8-slave-local list=mac-winbox
add interface=ether10-slave-local list=mactel
add interface=ether9-slave-local list=mac-winbox
add interface=wlan1 list=mactel
add interface=ether10-slave-local list=mac-winbox
add interface=bridge-local list=mactel
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
/interface pptp-server server
set default-profile=default
/ip accounting
set enabled=yes threshold=2560
/ip accounting web-access
set accessible-via-web=yes address=192.168.88.34/32
add address=192.168.88.1/24 comment="default configuration" interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=sfp1-gateway
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.88.23 client-id=1:0:f:ff:50:41:d9 mac-address=00:0F:FF:50:41:D9 server=default
add address=192.168.88.21 client-id=1:0:f:ff:12:9d:23 mac-address=00:0F:FF:12:9D:23 server=default
add address=192.168.88.24 client-id=1:0:f:ff:50:4a:d0 mac-address=00:0F:FF:50:4A:D0 server=default
add address=192.168.88.20 always-broadcast=yes client-id=1:0:f:ff:57:be:f7 mac-address=00:0F:FF:57:BE:F7 server=default
add address=192.168.88.10 comment="Netgear 24 Port Switch" mac-address=74:44:01:9B:34:34 server=default
add address=192.168.88.26 always-broadcast=yes client-id=1:0:f:ff:60:5:74 mac-address=00:0F:FF:60:05:74 server=default
add address=192.168.88.27 client-id=1:0:9:b0:cf:c7:15 comment=Receiver mac-address=00:09:B0:CF:C7:15 server=default
add address=192.168.88.22 mac-address=00:0F:FF:10:CA:04 server=default
add address=192.168.88.11 comment="Netgear POE Switch" mac-address=2C:B0:5D:7F:8A:51 server=default
add address=192.168.88.55 client-id=1:14:da:e9:4f:98:3d mac-address=14:DA:E9:4F:98:3D server=default
add address=192.168.88.51 always-broadcast=yes client-id=1:28:18:78:87:a0:85 disabled=yes mac-address=28:18:78:87:A0:85 server=default
add address=192.168.88.30 client-id=1:0:50:56:89:0:1 comment=DVR mac-address=00:50:56:89:00:01 server=default
add address=192.168.88.25 always-broadcast=yes mac-address=00:22:F4:17:BE:60
add address=192.168.88.50 client-id=1:2c:56:dc:97:84:da mac-address=2C:56:DC:97:84:DA server=default
add address=192.168.88.34 always-broadcast=yes client-id=1:c0:33:5e:15:a0:d9 mac-address=C0:33:5E:15:A0:D9 server=default
add address=192.168.88.33 always-broadcast=yes client-id=1:c0:ee:fb:5a:d1:e5 mac-address=C0:EE:FB:5A:D1:E5 server=default
add address=192.168.88.38 client-id=1:10:b:a9:56:b3:60 mac-address=10:0B:A9:56:B3:60 server=default
add address=192.168.88.36 always-broadcast=yes client-id=1:c0:ee:fb:5a:cf:b9 mac-address=C0:EE:FB:5A:CF:B9 server=default
add address=192.168.88.32 always-broadcast=yes client-id=1:78:4b:87:69:93:88 mac-address=78:4B:87:69:93:88 server=default
add address=192.168.88.31 always-broadcast=yes client-id=1:cc:95:d7:dc:94:ab comment="Vizio TV" mac-address=CC:95:D7:DC:94:AB server=default
add address=192.168.88.37 always-broadcast=yes client-id=1:ac:bc:32:8f:6f:51 mac-address=AC:BC:32:8F:6F:51 server=default
add address=192.168.88.12 comment=Unifi mac-address=80:2A:A8:D6:F1:3F server=default
add address=192.168.88.46 mac-address=F4:F5:D8:D7:C1:62 server=default
add address=192.168.88.45 always-broadcast=yes mac-address=F4:F5:D8:D7:C1:5A server=default
add address=192.168.88.28 client-id=1:0:9:b0:cf:e1:f9 mac-address=00:09:B0:CF:E1:F9 server=default
add address=192.168.88.56 always-broadcast=yes client-id=1:f0:6e:b:2d:3b:2b mac-address=F0:6E:0B:2D:3B:2B server=default
add address=192.168.88.29 always-broadcast=yes client-id=1:0:9:b0:e9:ca:a8 mac-address=00:09:B0:E9:CA:A8 server=default
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 name=router
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward connection-state=established,related
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established
add action=accept chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=sfp1-gateway
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=accept chain=forward comment="default configuration" connection-state=established
add action=accept chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=accept chain=forward connection-nat-state=dstnat dst-address=192.168.88.50 dst-port=7878 log=yes log-prefix=NavFilter protocol=tcp
add action=masquerade chain=srcnat comment="default configuration" out-interface=sfp1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-address=192.168.2.15 dst-port=7878 in-interface=ether1-gateway log=yes log-prefix=NavTest protocol=tcp to-addresses=192.168.88.50
/ip proxy
set cache-path=web-proxy1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1-gateway type=external
/lcd interface pages
set 0 interfaces=sfp1-gateway,ether1-gateway,ether2,ether3,ether4,ether5,ether6-master-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-slave-local
/system clock
set time-zone-autodetect=no time-zone-name=America/Toronto
/system ntp client
set enabled=yes primary-ntp=198.50.145.138 secondary-ntp=199.19.167.36
/system scheduler
add interval=1m name=station-check-schedule on-event="/system script run station-check ;" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=may/02/2014 start-time=00:00:01
/system script
add dont-require-permissions=no name=station-check owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/interface wireless registration-table\r
\n:foreach i in=[ /interface wireless registration-table find ap=no] do={\r
\n :if ([get $i tx-ccq] < "70" && [get $i rx-ccq] < "70") do={\r
\n :log warning ([get $i radio-name] . " was disconnected due to low CCQ - Tx: " . [get $i tx-ccq] . "% / Rx: " . [get $i rx-ccq] . "%")\r
\n /interface wireless registration-table remove $i\r
\n :delay 5s\r
\n }\r
\n}"
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
