Hello, I wanted to open port 25565 for server, but mikrotik don’t want open it.
I added Firewall Rule and NAT Rule, but it is still closed.
When call check packets moves:
NAT Rule is:
NAT Rule is:
Can you please post the config of the Mikrotik device
(/export hide-sensitive file=anynameyouwish)
Requirements for port forwarding…
A. Firewall rule generic that allows dst-nat packets intended for ports/IP on the router, as identified on dst-nat rules
B. The dst-nat rule specific to the server
Outcome on port testing software.
C. if the dst-nat rule has further delineations of which IPs are allowed to access the server from the WAN Side, (source address, or source address list)
To confirm a port forwarding is working two easy methods.
a. use your cell phone and access your server via the WAN port
b. get a friend to try and connect to your server using your WANIP address from their pc.
Port forwarding is a kind of bi-direction activity.
So please do not specify value in the column of in-interface list
