Port Forwarding
Doesn’t work for some reason. Router: hAP ac lite. RouterOS: 6.49.6.
NAT Rules:
 0    chain=srcnat action=masquerade out-interface=WAN
 1    ;;; CSGO Server
      chain=dstnat action=dst-nat to-addresses=192.168.1.254 to-ports=27015
      protocol=tcp in-interface=WAN dst-port=27015
 2    ;;; CSGO Server
      protocol=udp in-interface=WAN dst-port=27015
Thanks for help!
(Yes those ports are enabled in windows firewall)
Nothing wrong with your rules so I guess thats it then.
Clearly the rest of your config is inconsequential and you have found a bug which you should report to Mikrotik.
Or maybe you can actually share your config so we can see what is actually going on! :slight_smile:
Yeah sorry. Here:
add admin-mac=48:8F:5A:75:5C:C2 auto-mac=no comment=defconf name=local
set [ find default-name=ether1 ] name=WAN
add name=listBridge
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
    Profile supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country="Censored" disabled=no distance=indoors mode=ap-bridge \
    security-profile=Profile ssid=ManaMana2 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="Censored" disabled=no distance=indoors \
    mode=ap-bridge security-profile=Profile ssid=ManaMana5
add name=dhcp ranges=192.168.1.240-192.168.1.254
add name=dhcp_pool1 ranges=192.168.1.240-192.168.1.254
add address-pool=dhcp disabled=no interface=local name=dhcp
add bridge=local comment=defconf interface=ether2
add bridge=local comment=defconf interface=ether3
add bridge=local comment=defconf interface=ether4
add bridge=local comment=defconf interface=ether5
add bridge=local interface=wlan1
add bridge=local interface=wlan2
set discover-interface-list=listBridge
/interface detect-internet
set detect-interface-list=all
add interface=local list=listBridge
/interface wireless cap
set bridge=local discovery-interfaces=local interfaces=wlan1,wlan2
add address=192.168.1.1/24 interface=local network=192.168.1.0
/ip arp
add address=192.168.1.250 comment=SetTopBox interface=local mac-address=\
    1C:3A:DE:A4:06:07
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=no interface=WAN
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=accept chain=input connection-state=established,related
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
    new in-interface=WAN
add action=masquerade chain=srcnat out-interface=WAN
add action=dst-nat chain=dstnat comment="CSGO Server " dst-port=27015 \
    in-interface=WAN protocol=tcp to-addresses=192.168.1.254 to-ports=27015
add action=dst-nat chain=dstnat comment="CSGO Server" dst-port=27015 \
    in-interface=WAN protocol=udp to-addresses=192.168.1.254 to-ports=27015
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
/system clock
set time-zone-name=Censured
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
Public IP address, do you know what it is and do you have one?
If this is facing the internet the firewall ruleset it weak.
I still dont see anything stopping port forwarding though.
I am hoping another set of eyes will spot the issue!
