I was playing around with the router and I’m positive I broke my config because I cannot for the life of me get ports to open back up. At the bottom of the post I have attached the log and I’ve tried to get ports back open in both TCP and UDP with no luck.
I am trying to get ports 192.168.1.40:27015 (UDP) & 192.168.1.40:32600 (TCP) open.
Filter Rule Example:
add action=accept chain=forward comment="Port Opening: Homelab: TCP" \
dst-port=32600 in-interface="WAN LACP" protocol=tcp
add action=accept chain=forward comment="Port Opening: Homelab: UDP" \
dst-port=27015 in-interface="WAN LACP" protocol=udp
NAT (example):
add action=dst-nat chain=dstnat comment="Fen: 27015" \
dst-port=27015 in-interface="WAN LACP" protocol=udp to-addresses=\
192.168.1.40 to-ports=27015
add action=dst-nat chain=dstnat comment="Fen: 32600" dst-port=32600 \
in-interface="WAN LACP" protocol=tcp to-addresses=192.168.1.40
I’ve tried changing my in-interface to most of the different interfaces (bridge, WAN LACP, etc.) as well as broadening to include the in-interface-list WAN list. When I use a port checker like canyouseeme.org/yougetsignal it will either timeout or tell me the port isnt open. Oddly enough my counters are still moving in both filter rules and NAT, so I assume its getting some packets and Im just missing something small and silly.
# sep/19/2023 20:22:19 by RouterOS 6.48.2
# software id = WBCW-3MQ3
# model = RB4011iGS+
# serial number = DDDDDDDDDDD
add admin-mac=11:11:11:11:11:99 auto-mac=no comment=defconf name=bridge
/interface bonding
add comment="Main Home LACP" mtu=1504 name=Home-Main slaves=\
ether6,ether7,ether8,ether9 transmit-hash-policy=layer-2-and-3
add comment="Homelab LACP" mtu=1504 name=Homelab slaves=ether3,ether4,ether5 \
add comment="WAN LACP" mode=802.3ad name="WAN LACP" slaves=ether1,ether2 \
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="Homelab - NO SETUP" name=Homelab ranges=\
192.168.1.10-192.168.1.254
add comment="Home/Main - NO SETUP" name=Home-Main ranges=\
192.168.2.10-192.168.2.254,192.168.3.19-192.168.3.254
add comment=Default name=Backup ranges="192.168.3.10-192.168.3.254,192.168.4.1\
0-192.168.4.254,192.168.2.10-192.168.2.254,192.168.88.10-192.168.88.254,19\
2.168.1.10-192.168.1.254"
add comment=Default name=secondary-dhcp ranges="192.168.4.10-192.168.4.254,192\
.168.2.10-192.168.2.254,192.168.88.10-192.168.88.254,192.168.1.10-192.168.\
1.254"
add comment=Default name=default-dhcp next-pool=secondary-dhcp ranges=\
add add-arp=yes address-pool=default-dhcp disabled=no interface=bridge name=\
defconf
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge interface=Home-Main pvid=2
add bridge=bridge interface=Homelab trusted=yes
add comment=defconf interface="WAN LACP" list=WAN
192.168.88.0
add address=192.168.1.1/24 comment="Homelab IP Address Range" interface=\
Homelab network=192.168.1.0
add address=192.168.2.1/24 comment=\
"Main Home IP Address Range - Trusted Static IPs" interface=Home-Main \
network=192.168.2.0
add address=192.168.3.1/24 comment="Dynamic (Untrusted) Addresses" interface=\
Home-Main network=192.168.3.0
add address=192.168.4.1/24 comment=Monitored/Family interface=Home-Main \
network=192.168.4.0
/ip dhcp-client
add comment=defconf disabled=no interface="WAN LACP"
/ip dhcp-server lease
add address=192.168.1.20 client-id=1:11:11:11:11:1:ac comment=\
"Homelab: Fen" mac-address=1:11:11:11:11:1:ac server=defconf
add address=192.168.1.21 client-id=1:11:11:11:11:1:ac comment=\
add address=192.168.1.40 client-id=1:11:11:11:11:1:ac comment=\
add address=192.168.1.0/24 dns-server=192.168.1.1,1.1.1.1,1.0.0.1 gateway=\
192.168.1.1 netmask=24
add address=192.168.2.0/24 gateway=192.168.2.1
add address=192.168.3.0/24 comment=Untrusted gateway=192.168.3.1
add address=192.168.4.0/24 comment=Monitored dns-server=192.168.1.60 gateway=\
192.168.4.1
add address=192.168.5.0/24 comment="OLD Monitored (TEMP)" dns-server=\
208.67.222.222,208.67.220.220 gateway=192.168.4.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
/ip firewall address-list
add address=192.168.3.0/24 comment="For blocking unrecognized devices" list=\
"Block External Access"
add action=accept chain=input comment="Accept ICMP" protocol=icmp
"Allow Related / Established / Untracked" connection-state=\
established,related,untracked
add action=fasttrack-connection chain=forward comment=\
"Fasttrack (Not sure if needed)" connection-state=established,related \
disabled=yes
"Accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
"Accept in ipsec policy" disabled=yes ipsec-policy=\
in,ipsec
"Accept out ipsec policy" disabled=yes ipsec-policy=\
out,ipsec
"Drop all not coming from LAN" disabled=yes \
in-interface-list=!LAN
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
disabled=yes
add action=drop chain=forward comment="For Blocking Unauthorized Devices" \
disabled=yes in-interface=bridge src-address=192.168.3.0/24 \
src-address-list="Block External Access"
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=input comment="Drop everything not whitelisted" \
add action=drop chain=forward comment="Drop everything not whitelisted" \
connection-nat-state="" connection-state=new in-interface="WAN LACP"
/ip firewall raw
add action=notrack chain=prerouting comment=\
"Let devices talk between subnets" dst-address=192.168.1.0/24 \
src-address=192.168.88.0/24
"Let devices talk between subnets" dst-address=192.168.2.0/24 \
src-address=192.168.1.0/24
"Let devices talk between subnets" dst-address=192.168.88.0/24 \
src-address=192.168.2.0/24
/ip upnp
set allow-disable-external-interface=yes enabled=no
/ip upnp interfaces
add interface=Home-Main type=internal
add interface=bridge type=external
/system clock
set time-zone-name=America/Denver
/tool mac-server
/tool mac-server mac-winbox
