Port forwarding
HI All! I’m new at MikroTik from Argentine, and I have some problems about port forwarding. I have a simple web cam at port 80 and I try to watch it from external (WAN) connection with no success. Of course it works on LAN.
I’m uging Menu → IP → Firewall > add Chain = INPUT Dst. Address = “My internal cam IP” Protocol=TCP Scr. POrt=120 Dst. Port =80 Action=Accept.
Can somebody help me pleasE? I try with many other options wit no success
Once I make some changes and click “Apply” it has instant impact? (I suposse Its not need to reboot)
Thanks in advance!
Sorry for my poor English please!
/export file=anynameyouwish ( minus router serial number, any public WANIP information )
It should be quick to find the issue!
also.
a. confirm you are using LANIP of server to reach from LAN?
b. confirm you have a public IP address (static or dynamic)
OR
you have an ISP router that has a public IP address and you can port forward from the ISP router to the MT router.
Simple answer is that you need a port forwarding NAT. However do as Anav said and export your configuration.
Please share your public IP besides the config, so we can watch the camera as well :sunglasses:
Meaning…are you sure you want to have a camera publically available? Have you considered a more secure solution like VPN?
If you can, please change default port…
HI anav
Thanks for answer.
sorry you mean I share dump code? Not sure if its ok due forum politics. Im no problem. I read it bu not sure to see nothing estrange.
Since about 10 years i have been doing this without problem. My old router crashes so I bought a new one. So I KNOW I can do this. I like my MikroTik it’s very fast!
a) not sure. I can see the camera from LAN :wink:
b) I have public IP 152.170… (changes weekly or so) This is why I need a DDNS too (cannot make it work neither)
c) I suposse withb) is answered
THANKS!!!
also.
OR
[/quote]
HI!
Thanks!
camera port or external port? may be both?
HahHahah
Not probem to me.. nothing important. As i said before IP changes weekly or so… I have a DDNS and password. I’m not member of secret service :wink:
THANKS for your repply
[/quote]
HI k6ccc!
Not sure if I can reach my camera from outside with this technique. I’m newbie about NAT. I will try to learn more.
THANKS!
Since you didnt bother to post config, Im outta here good luck. Others have more patience than I.
HI anav.
sorry for delay ! I read some post on HOW to send router config. Hope I’ve done well!
please don misunderstand me. Thanks
# 2025-04-15 18:45:01 by RouterOS 7.18.2
# software id = *******
# model = E50UG
# serial number = *******
add admin-mac=******* auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.100-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
set discover-interface-list=LAN lldp-med-net-policy-vlan=1
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface ovpn-server server
add mac-address=FE:33:86:FA:C5:26 name=ovpn-server1
    192.168.88.0
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.11 client-id=1:a8:20:66:12:3f:a2 mac-address=\
    A8:20:66:12:3F:A2 server=defconf
add address=192.168.88.20 client-id=1:d0:d2:b0:94:38:6e mac-address=\
    D0:D2:B0:94:38:6E server=defconf
add address=192.168.88.10 client-id=1:a0:36:bc:58:ae:a2 mac-address=\
    A0:36:BC:58:AE:A2 server=defconf
add address=192.168.88.21 mac-address=00:05:CD:A0:B9:E9 server=defconf
add address=192.168.88.30 client-id=1:90:f6:52:ee:76:6f mac-address=\
    90:F6:52:EE:76:6F server=defconf
add address=192.168.88.3 client-id=1:7c:f1:7e:66:84:a0 mac-address=\
    7C:F1:7E:66:84:A0 server=defconf
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=passthrough chain=forward comment=CAM dst-address=192.168.88.30 \
    dst-port=80 protocol=udp src-port=120
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ppp secret
add name=vpn
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system note
set show-at-login=no
/tool e-mail
set from="" server=none
/tool mac-server
/tool mac-server mac-winbox
Just put this in terminal adding cam local address in the code and reach the camera on public ip port 8081:
ip fi n add chain=dstnat in-interface-list=wan port=8081 protocol=tcp action=dst-nat to-addresses=cam_address to-ports=80
I would revise the following:
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
TO:
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else:
For the port forwarding rule one needs to add the following:
/ip firewall address-list
add address=mynetname.net list=MYWAN comment=“resolve my WANIP using IP cloud”
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=
192.168.89.0/24
add chain=dstnat action=dst-nat dst-address=MYWAN dst-port=80
protocol=tcp to-address=192.168.88.30
As noted, this makes your cameras susceptible to hacking from the outside and is not recommended,
Can you not use wireguard vpn, to access the router and then the camera??
Who is accessing the camera and from where and how( app, IP address??)
HI anav!
Thanks a lot!!
sadly still doesn’t work :frowning: but
I cannot import the configfile so I added it by advanced menu
I DELETE
AND I DELETE
dst-port=80 protocol=udp src-port=120[/size][/i][/b]
AND I ADD
AND I ADD
AND I ADD
add action=drop chain=forward comment="drop all else:[/i]
IN MENU IP → firewall → address-list
I ADD
add address=mynetname.net list=MYWAN comment=“resolve my WANIP using IP cloud”[/i]
(replace mynetname.net for xxxxxxx.xxxxxx.mynetname.net
(MYWAN is a new nae. is ok that or mus I replace it with some internal REAL name?
FINALLY in menu IP → firewall → nat
I ADD
(I change dst-addres (an IP number) for Dst. Address List (it uses the MYWAN name)
(no source port?)
OF course I understand this But I dont know a better option, that I can use
I have no idea
Only me access the CAMERA , from a phone with an app so I need an IP or domain name to get directed. The app name is “ipcamviewer”
THANKS A LOT
So you are using a third party APP to access your feed.
Have you thought about the fact that you have to forward a port on your router to everyone in the world…
I have three different types of video cameras in the house and I dont forward a single port and I also use an APP to view them.
In other words, you should stop immediately what you are doing and remove the port forward and setup a wireguard connection to your router (not hard), and then you can view the cameras from INSIDE your router/home.
HI and thanks
I understand but I DONT AGREE
why> simply. My cam onlyworks a little (fwe hours a day)
Its beyond ddns
user and key
It works and I konw how to do that
but learn hot to setup a wireguard connection, find a program to do tha , config and so on is beyond my time. Thats all. Im not the FED :stuck_out_tongue:
thank you
(I will continue learning mikroik programing codes)
