port forwarding
I have two IP cameras in the mikrotics net which I need to connect from outside (internet). I have public IP. In the microtic IP/firewall I set up dst-nat so when I want a port 95 or 96 it goes to one of the cameras.
It does not work. It gets to the mikrotic but no further. Can anyone advice me what to change?
Upload your config using output from /export compact. Destination NAT is what you want and the devices need to be using the router’s internal address as their default gateway.
