I have installed a DVR on a wireless network. The DVR is looking for port 80 and 6036 to be forwarded.
From inside the network I can get to the DVR using the internal IP address of 10.0.0.222 but no matter how I try and do port forwarding using Winbox I can't seem to get it to work.
I have tried to set up both a dsnnat firewall rule to point the static external address of 173.14.161.229 to the internal address and a srcnat rule to point the 10.0.0.222 address back out to the 173.14.161.229 address with no luck
The network just has two interfaces ether1 and wlan1. If I try and use the interface on the port forwarding rules it still doesn't work - If I pick wlan1 as the in interface then all the web traffic gets routed to the DVR from the inside network. If I pick ether1 as the in interface then it just doesn't do anything
Both the DVR and the router support Upnp - but I can't get that to work either
There is a masquerade rule set up but I've tried moving the port forwarding rules before and after it.
The masquerade rule has the src address of 10.0.0.0/24 and the out interface of ether1.
I must be missing something basic but I can't figure it out - anyone got any ideas?
One last thought - there is already a web camera set up on port 3385 connected to the ether1 interface with an internal address of 192.168.1.199:3385 and an external address of 173.14.161.299:3385 and I can find NO PORT forwarding rules at all for this setup and it is working just fine.
From the 10.0 network I can ping 192.168.1.1 and .254 and the external addresss of 173.14.161.229 but I can not ping and computers connected directly to the Ether1 interface - from the computers on the ether1 interface I can not ping any computers on the 10.0 network.
Here is the results of an export
(sorry it is so long)
jan/11/1970 17:17:49 by RouterOS 5.21
software id = FEHM-WHTH
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 mac-address=
00:0C:42:0B:69:B6 mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes
l2mtu=1522 mac-address=00:0C:42:0B:69:B7 master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes
l2mtu=1522 mac-address=00:0C:42:0B:69:B8 master-port=none mtu=1500 name=ether3 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types="" eap-methods=passthrough group-ciphers=""
group-key-update=5m interim-update=0s management-protection=disabled management-protection-key=
"" mode=none name=default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX
radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none
static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=""
wpa-pre-shared-key="" wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=tkip group-key-update=5m
interim-update=0s management-protection=disabled management-protection-key="" mode=dynamic-keys
name=profile1 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=""
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity="" tls-certificate=none
tls-mode=no-certificates unicast-ciphers=tkip wpa-pre-shared-key=vtdocks332 wpa2-pre-shared-key=
vtdocks332
/interface wireless
set 0 adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2ghz-b
basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=enabled burst-time=
disabled channel-width=20mhz compression=no country=no_country_set
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=
no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2412
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=
00:15:6D:64:78:D7 max-station-count=2007 mode=ap-bridge mtu=1500
multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key=""
nv2-qos=default nv2-queue-count=2 nv2-security=disabled
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=00156D6478D7
rate-selection=advanced rate-set=default scan-list=default
security-profile=profile1 ssid="The Moorings" station-bridge-clone-mac=
00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wireless-protocol=any wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40-0:0,
HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0
split-user-domain=no use-radius=no
/ip hotspot profile
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=10.0.0.2-10.0.0.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=wlan1 lease-time=3d name=dhcp1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
pcq-dst-address6-mask=128 pcq-limit=50 pcq-rate=0 pcq-src-address-mask=32
pcq-src-address6-mask=128 pcq-total-limit=2000
add kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=
ospf-in metric-bgp=auto metric-connected=20 metric-default=1
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=
0.0.0.0 syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:80:82:F4:05:DC
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.0.1/24 disabled=no interface=wlan1 network=10.0.0.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no interface=
ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=10.0.0.0/24 dhcp-option="" dns-server="" gateway=10.0.0.1
ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 servers=192.168.1.1,68.87.71.226
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=
"place hotspot rules here" disabled=yes
"place hotspot rules here" disabled=no to-addresses=0.0.0.0
add action=masquerade chain=srcnat disabled=no out-interface=ether1
src-address=10.0.0.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no src-address=10.0.0.0/24 to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set wlan1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=ether1 type=external
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators=""
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system health
set fan-mode=auto use-fan=main
/system identity
set name="Moorings Wireless"
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-the
boot-protocol=bootp cpu-frequency=680MHz enable-jumper-rese
enter-setup-on=any-key force-backup-booter=no silent-boot=n
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 seconda
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m w
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes m
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no use
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=
/tool sniffer
set file-limit=10KiB file-name="" filter-ip-address="" filter-i
filter-mac-address="" filter-mac-protocol=!ip filter-port="
filter-stream=yes interface=all memory-limit=10KiB memory-s
only-headers=no streaming-enabled=no streaming-server=0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim
use-radius=no
