Port forwarding
Could someone please put me in the right direction.
Im trying to open a port to my razberry, so i can access i from my mothers house.
I have read the forum for a couple of days but i cant get it to work.
Is there anybody that could make a step by step turtorial?
Raz ip 192.168.88.223
external ip 90.xx.xx.xx
Edit: i have a mikrotik rb2011uas-2hnd-in
Which port and protocol are you trying to use?
Port 8083
protocol tcp
add action=dst-nat chain=dstnat` dst-port=8083 \
    in-interface=ether1-gateway protocol=tcp\
    to-addresses=192.168.88.223 to-ports=8083
I have tried that and did it again, but no luck :frowning:
i dont have to do anything in firewall filter rules?
Post your config. Also are you trying to access it from within the network, by the public ip? (e.g. hairpin)
im trying to connect via public ip xx.xx.xx.xx:8083
How do i get out the config? :blush:
Open a new terminal and type /export compact if using v5 or if using v6 just /export will be fine.
Right, but are you trying to connect via public IP from inside your 10.0. network? Or from the internet? If you are doing it from within you will need hairpin rules also.
/ip firewall export
im trying to connect from the internet.
Firewall export
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no \
    protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established disabled=no
    connection-state=related disabled=no
add action=drop chain=input comment="default configuration" disabled=no \
    in-interface=sfp1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    no out-interface=sfp1-gateway
    no out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat disabled=no dst-port=8083 in-interface=\
    ether1-gateway protocol=tcp to-add
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 si
set pptp disabled=no
[admin@MikroTik] >
Your dst-nat rule does not look correct. Did you cut it off trying to paste it or is it just wrong?
It should be.
add action=dst-nat chain=dstnat dst-port=8083 protocol=tcp to-addresses=192.168.88.223
must have been me when i past it.
is this all that i need?
Yes, unless you are wanting to send port 8083 coming in on your WAN to a different port on the Rasberry (let’s use 80 for example) then you would add “to-ports=80”. It also doesn’t hurt to specify the WAN interface with “in-interface”. The resulting rule then would like.
add action=dst-nat chain=dstnat dst-port=8083 in-interface=ether1 protocol=tcp \
But if you don’t need that then just use
ill get this when i tried
[admin@MikroTik] > /ip firewall nat
[admin@MikroTik] /ip firewall nat> add action=dst-nat chain=dstnat dst-port=8083 i
... to-addresses=192.168.88.223
ambiguous value of interface, more than one possible value matches input
That is because your WAN interface is not named ether1. Change out ether1 with the interface name of your WAN interface.
Ahhh ether1-gateway :slight_smile:
But no luck so far, ihave tested everything, when i check the staistic it happens nothing :frowning:
It must be my modem that stops this, i have even put the mikrotik router in dmz in my modem, i cant bride the modem.
Torch your WAN interface and see if you see the traffic coming in.
As was stated earlier. If you are trying to connect to the to the server via the public IP and setting on the same LAN as the server you will need to setup a hairpin nat rule.
Im not at home so im not in the same LAN :slight_smile:
Torch doesent show my ipadress at any time, so my call to my raz never gets to the router.
Topic solved
Many thanks for the help :slight_smile:
No problem. What was the final fix?
