Port forwording
hallo
I m trying to do a portforwording to my hotspot network. I m using this topic http://www.icafemenu.com/how-to-port-forward-in-mikrotik-router.htm
nb. there is no vlan its a flat network
To access any device on the hotspot interface, that device must be logged in or bypassed. Otherwise, the connection will fail. If the device IP is 192.168.0.2, then this will bypass the device. You can also use the mac address if the IP will vary.
/ip hotspot ip-binding
add address=192.168.0.2 type=bypassed
