We are having issues with the port forward, we are trying to access an Apache server in our LAN reaching it from the Public IP, example 123.145.24.133:8080 should redirect us to 10.6.0.56:9432 but we can’t even ping this IP.
The port forward works in a simple structure using only one ISP and LAN, but when we add others ISP and create a bonding the stop working.
Functional config:
# mar/05/2020 17:07:24 by RouterOS 6.46.3
# software id = 7HLW-XGSQ
# model = CCR1036-12G-4S
add name=bridge1
set [ find default-name=ether3 ] comment="ISP 3" name=\
"ether3" speed=100Mbps
add name=dhcp_pool0 ranges=10.6.0.2-10.6.0.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=ether6
add address=123.145.24.133 interface="ether3-Cable Wireless" network=\
123.145.24.133
add address=10.6.0.1/24 interface=bridge1 network=10.6.0.0
/ip dhcp-server network#$
add address=10.6.0.0/24 gateway=10.6.0.1
set servers=8.8.8.8,10.6.0.1
add action=drop chain=forward
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface=all-ethernet
add action=drop chain=input
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward out-interface=all-ethernet
add action=accept chain=forward connection-nat-state=dstnat
add action=dst-nat chain=dstnat dst-address=123.145.24.133 dst-address-type=\
local dst-port=8080 protocol=tcp to-addresses=10.6.0.54
local dst-port=11194 protocol=udp to-addresses=10.6.0.56
add distance=1 gateway=123.145.24.133 routing-mark=CableAndWireless-OUT
add distance=2 gateway=123.145.24.132
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=America/Costa_Rica
Below you will see a little bit more complex structure where we can’t even ping the IP. We suppose we are having some firewall problems.
set [ find default-name=ether1 ]
set [ find default-name=ether2 ]
set [ find default-name=ether4 ]
set [ find default-name=ether5 ]
set [ find default-name=ether10 ]
set [ find default-name=ether11 ]
set [ find default-name=ether12 ]
add comment="Bonding VLANs" mode=active-backup name=test primary=\
"ether10-test TRUNK" slaves="ether10-test TRUNK,ether11-test TRUNK"
/interface vlan
add interface=test name=test.111-car vlan-id=111
add interface=test name=test.114-car2 vlan-id=114
add interface=test name=test.115-car3 vlan-id=115
add interface=test name=test.119-car5 vlan-id=119
add interface=test name=test.202-car4 vlan-id=202
add name=dhcp_pool4 ranges=10.6.0.2-10.6.0.254
add name=dhcp_pool5 ranges=10.9.0.2-10.9.0.254
add address-pool=dhcp_pool4 disabled=no interface=test.111-car name=dhcp1
add address-pool=dhcp_pool5 disabled=no interface=test.119-car5 name=\
dhcp2
add interface="ether4-###"
add interface="ether5-###"
add interface=ether6
add address=10.6.0.1/24 comment="VLAN car" interface=test.111-car \
network=10.6.0.0
add address=10.5.0.1/24 comment="VLAN car2" interface=test.114-car2 \
network=10.5.0.0
add address=10.7.0.1/24 comment="VLAN car3" interface=test.115-car3 \
network=10.7.0.0
add address=10.8.0.1/24 comment="VLAN car4" interface=test.202-car4 network=\
10.8.0.0
add address=10.9.0.1/24 comment="VLAN car5" interface=\
test.119-car5 network=10.9.0.0
add address=### interface=ether1-### \
network=###
add address=### interface=\
ether2-### network=###
add address=123.145.24.133 interface=ether3-C&W \
network=123.145.24.132
"ether4-###" network=###
"ether5-###" network=###
add address=10.6.0.0/24 dns-server=8.8.8.8,10.6.0.1 gateway=10.6.0.1
add address=10.9.0.0/24 dns-server=8.8.8.8,10.9.0.1 gateway=10.9.0.1
set servers=8.8.8.8,10.5.0.1,10.6.0.1,10.7.0.1,10.8.0.1,10.9.0.1
established,related
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=C&W-OUT \
passthrough=yes src-address=10.6.0.0/24
add action=masquerade chain=srcnat comment="Masquerade ###" out-interface=\
ether1-###
add action=masquerade chain=srcnat comment="Masquerade ###" \
out-interface=ether2
add action=masquerade chain=srcnat comment="Masquerade C&W" out-interface=\
ether3
out-interface="ether4"
out-interface="ether5"
add action=dst-nat chain=dstnat comment="APACHE TEST NAT " dst-address=\
123.145.24.133 dst-address-type=local dst-port=8080 protocol=tcp \
to-addresses=10.6.0.53
add check-gateway=ping distance=1 gateway=123.145.24.132 routing-mark=TEST
add check-gateway=ping distance=1 gateway=### routing-mark=\
add check-gateway=ping distance=1 gateway=### routing-mark=###
/ip service
