After 2 days it’s almost hammer time.
How do I route a port/interface somewhere.
Source is not an ip or mac. Just any device regardless of ip plugged in that specific port will be routed over the vpn.
Don’t mind the vpn part just want to know how to route ports/interfaces.
This afternoon the samba shares showed up fine. Now they are unreachable from this subnet while the nas page still is.
in /ip route - add interface to desired dst address
I don’t see how to add an interface directly as source.
I made a pptp interface wich is connected to a vpn service and I need :
ether8-slave-local
To use it.
Only that interface regardless of ip adress it has. Whatever cable gets plugged in that port should use the vpn.
It works if I use ip adresses but I can’t seem to choose an interface as source anywhere.
If you route Source ip . not dst ip -. use rute rule and or Connection/Routing mark in mangle firewall
