port mapping SNMP inside address for Dude
I have Dude on an public address, and I have created a SNMP rule in dude profile of Paradise SU SNMP community: Public123 version 1 port 5163. So on my mikrotik GW hotspot, I have created a port map to an UBNT Rocket M5 on the inside of the network:
/Ip firewall nat
add action=dst-nat chain=dstnat comment=“Paradise SU SNMP port map” dst-address=xx.xx.39.46 dst-port=5163 protocol=udp to-addresses=10.200.1.4 to-ports=161
and
add action=dst-nat chain=dstnat comment=“Paradice SU” dst-address=xx.xx.39.46 dst-port=4003 protocol=tcp src-address-list=“access list” to-addresses=10.200.1.4 to-ports=2048
So I can login to the radio thru the port map and that works fine, but when I do an SNMP walk, it is pulling SNMP info from the mikrotik gateway hotspot, instead of the radio that is inside.
Anyone have a clue how to fix this, to direct the snmp query to the radio and not to the mikrotik gw on xx.xx.39.46
the ideal is a routed network where the dude reaches each radio IP without NAT. Do not know if this way you will get success did
