I’m new to MikroTik - and am trying to put some webcams to ports on the router. I can connect to them fine inside the network, but from outside I can see packets coming in but noting appears to be going out. I’m using webfig and followed the rule for port mapping in the manual “Firewall / NAT”. These are the lines I have edited for one of the cams (D-Link DCS-930L):
Chain dstnat
Protocol 6 (tcp)
Dst. Port 808
Action dst-nat
To Addresses 192.168.88.87
To Ports 808
The manuals gives this example for a port map and I think I have everything covered in WebFig:
/ip firewall nat add chain=dstnat dst-port=1234 action=dst-nat protocol=tcp to-address=192.168.1.1 to-port=1234
My port I want to use is 808 for this one cam, and the webcam is set up on 192.168.88.87:808. When I access it from outside I can see the bytes and packets count increment in WebFig - but no connection happens. Inside I have no problems. I’m new to MikroTik and this seems like it should be straightforward. My old Linksys router was a simple fill in the blank for NAT, I know the MikroTik is much more complex. I don’t want to set up a source IP as that could change, and the example shows it is not necessary. What am I doing wrong? Thanks, Mike
