I’m a bigginer and I have bought a CRS125-24G-1S-RM. I need to mirror ports on the Switch.
I have tried chacking and below is what I manage to do:
admin@OTEL Switch] /interface ethernet switch> print
type: QCA-8513L
bridge-type: service-vlan-bridge
drop-if-no-vlan-assignment-on-ports:
drop-if-invalid-or-src-port-not-member-of-vlan-on-ports:
invalid-vlan-lookup-mode: ivl
forward-invalid-vlan: yes
use-svid-in-one2one-vlan-lookup: no
use-cvid-in-one2one-vlan-lookup: yes
mac-level-isolation: no
vlan-level-isolation: no
ipv4-multicast-lookup-mode: dst-mac-and-vid-always
override-existing-when-ufdb-full: no
unicast-fdb-timeout: 5m
ingress-mirror0-enable: yes
ingress-mirror0-port: ether2
ingress-mirror0-format: modified
ingress-mirror1-enable: yes
ingress-mirror1-port: Sentinel - ether3
ingress-mirror1-format: modified
ingress-mirror-ratio: 1/1
egress-mirror0-enable: yes
egress-mirror0-port: ether2
egress-mirror0-format: original
egress-mirror1-enable: yes
egress-mirror0-port: Sentinel - ether3
egress-mirror1-format: modified
egress-mirror-ratio: 1/1
egress-sampling-ratio: 1/1
fdb-uses: mirror0
vlan-uses: mirror0
mirror-egress-if-ingress-mirrored: yes
mirror-tx-on-mirror-port: yes
mirrored-packet-qos-priority: 0
mirrored-packet-drop-precedence: green
bypass-vlan-ingress-filter-for:
bypass-l2-security-check-filter-for:
Please help as I cannot seem to get it working. I need to mirror Ether2 with Ether3
My CRS came with 6.5 and I used up to 6.11 (now down to 6.10 - i try to reproduce a switch bug).
But the switch commands didn’t change to much between these versions.
I applied the cmd as specified in the wiki for the master port (ether1), but still cannot see any traffic using torch for the slave ports. Can someone help? tnx
Tnx for the quick response. This is actually the default configuration which indeed works for torch capturing all routed communication from the internal network. But, do I have the chance to also capture switch level communications between hosts residing on the same subnet? Can this be supported by torch or I need to use wireshark from an individual host? Torch would be ideal for my case. It is critical because I need to capture some internal tcp connections.
You can configure ingress/egress port mirroring from any physical CRS switch port to the “switch1-cpu” port and you will see that traffic when running Torch on the master-port.
set ingress-mirror0=switch1-cpu egress-mirror0=switch1-cpu
set ether6 egress-mirror-to=mirror0 ingress-mirror-to=mirror0
Note that a lot of mirrored traffic to the CPU will increase its usage and may cause connectivity issues.
