I’m searching for a switch that would allow me to bridge a VoIP network and data network (using VLANs) but also port mirror across the VLANs to packet sniff the VoiP network, aside from this, I would need the destination port of the mirror to still be usable, so I could still send data over the network to the internet.
Could this be achieved using a RouterOS router? I’ve seen the great switch creation tools available, but I’m not sure if the VLAN tagging would work in the way I need* or if I could still use the destination port of the mirror.
Here’'s an example usage:
Port 1 - Computer
Port 2 - Rest of the network / internet
Port 3 - IP phone
Port 4 - Rest of VoIP network
A mirror would be set up from Port 3 with the destination port set as Port 1. I would like to then be able to access the internet from the computer on Port 1, as well as sniff the mirrored VoIP packets.
Port 1 and Port 2 would be in VLAN 1 and ports 3 and 4 would be in VLAN 2.
VLAN tags would be applied on packets entering the switch on all ports; VLAN-ID 1 for ports 1 and 2; VLAN-ID 2 for ports 3 and 4.
The VLAN tags could then be stripped when leaving all ports (the devices connected would not be VLAN aware).
The overall aim here is to sniff the VoIP packets without physically bridging the two networks.
Any advice would be greatly appreciated.
*I’ve read ( http://blog.butchevans.com/2010/02/to-tag-or-not-to-tag-that-is-the-question/#more-176 ) that routerOS will always add the VLAN tag corresponding to the VLAN-ID of the port that the packet left. I would need the tags to be applied when the packets entered, and stripped as they left.
