Hello, I need to configure some router for rtsp streaming of some security cameras.
In a remote location I have a Starlink antenna and a Mikrotik router connected to it. The mikrotik router is connected to a Cambium radio antenna that transmits the signal to 3 different location. In each of this location I have connected a Mikrotik router. On each Mikrotic router I have connected 2 security cameras. At the moment I have installed on the 3 routers in the remote locations a L2TP vpn wit fix public ip address. In this way each of the 3 routers has his fixed pubic ip address and I can access remotely the cameras via RTSP by opening the 554 port of the camera. For the camera I also opened port 8080 so that I can remotely access the camera settings. And I opened the router 80 port so that I can remotely access the router settings. This is working all fine, but I noticed that on Starlink I can activate a public ip address (not fixed, but I will use DDNS). In this way I could avoid paying the 3 vpn service and use the starling public ip address. The problem is that in that way I don’t know how configure the mikrotik routers so that I can access remotely all the cameras and the routers with the starlink public ip address. Could someone help me setting this configuration? Thank you very much
Nobody that could help me?
I would start with a detailed network diagram to ensure everything is understood correctly..
What experience level do you have with MT routers??
What have you configged for this scenario thus far??
