Port Probe
HI,
I want to check if some port are up or down on my switchs.
To do that i’ll create a Probe ( for example ) :
Type : TCP
Port : 465
Agent : Default
And i select connect only
I test it on my VM windows server 2008 and my computer ( windows 7 )
But i have some trouble : Some port are not availaible as they were opened ont he machine : i have a message who said me : ( Connection failed : No connection could be made because the target machine actively refused ). ( It’s work at the begining…)
Also when i turn off my VM, the probe port still say : Ok.
Did i miss something ?
Thanks.
The probe are useless,
First of all, run this on x86 machine:
/interface ethernet set [ find ] disable-running-check=no
You can personalize what ethernet or sfp you want to check.
create new functoin called check_ether1:
if(device_property("Ros"),ros_command(":if ([/interface ethernet get [find where default-name=\"ether1\"] value-name=running]) do={:put 1} else={:put 0}"),0)
Create new Probe:
Type: Function
Agent: default
Available: check_ether1()
Error:
if(check_ether1() < 1, "warning", "")
Value: check_ether1()
Unit: (leave blank)
And now you can add probe on the panel “Services” for any device you want.
It also be on graph!
If anyone use this function or probe, please add Karma. Thanks.
This probe is universal for any device, including switches, routers, Windows servers or workstations:
<?xml version="1.0" ?>
<dude version="4.0beta3">
 <Probe>
  <sys-type>13</sys-type>
  <sys-id>20853</sys-id>
  <sys-name>interfaces port status port 01</sys-name>
  <typeID>5</typeID>
  <snmpProfileID>10001</snmpProfileID>
  <snmpOid>1.3.6.1.2.1.2.2.1.8.1</snmpOid>
  <snmpOidType>integer</snmpOidType>
  <snmpCompareMethod>==</snmpCompareMethod>
  <snmpValueNumber>1</snmpValueNumber>
  <functionAvailable></functionAvailable>
  <functionError></functionError>
  <functionValue></functionValue>
 </Probe>
</dude>
Just change SNMP OID from 1.3.6.1.2.1.2.2.1.8.1 (this one is for first port in system) to number of port you need.
On Windows Severs this number can be high (like 65530), so don’t be surprised if you see something like that in SMNP Walker. :slight_smile:
If port is up, then value is 1. If down, value is 2 and alarm raised.
Probe from original post is to check if some service (and 465 is Secure SMTP) running on device. This is not related to interface port on device.
