Is there a way to turn on something like cisco port-protected in RouterOS EoIP Bridge environment ?
Regards.
Faton
Regards.
Faton
You can use bridge horizon feature to disable forwarding between bridge ports. See
http://wiki.mikrotik.com/wiki/MPLSVPLS#Split_horizon_bridging
No data is forwarded between bridge ports configured with the same horizon value. This can be used to break loops without using (R)STP (e.g. like in VPLS case), but can also be used for other purposes.
Thanks a lot,
it looks fine, but as far as I see it is only applicable in ver.3.x and not in any ver.2.9, but anyway if it is necessary I will upgrade the EoIP-concetrator to ver.3.14
Regrads, and thanks again for your feedback.
Faton
