Port Sanitization Help Needed with STP
I cant get my CRS317-1G-16S+ running ROS 7.15.3 to stop sending STP packets on a bonded interface. I have done packet captures and the source MAC address of the STP is the same as the bonding1 which currently includes a single interface, sfp-sfpplus3. I had this working without the bonding1 interface where I simply had sfp-sfpplus3 as a port in the bridge and set the edge port to yes as well as PTP. I don’t know why it is still sending the STP packets every 15 seconds roughly. Before the bonding1 interface I had run packet capture for an hour on sfp-sfpplus3-ohio_ix and had 0 packets captured proving to me that I had properly sanitized the port as it is a requirement on the internet exchange. I have attached the config. Can someone help point out what I am missing?
config.rsc (56.1 KB)
I opened a ticket as well with MIkrotik. I just don’t understand that if you turn off STP on the bridge and set the port to PTP with no discover and as an edge port then turn off discovery on the interface under ip neighbors why the interface would still be sending out STP packets? Ughh!
remove config, still contain personal IP and info…
