Does connection tracking need to be enabled in v3 for the port scan rules which check the tcp flags on the packets to work?
Or, will all the rules work fine without connection tracking. I know the rules are looking at packets, but I want to be sure…
Scott
Chupaka
November 13, 2007, 11:45pm
3
could you please post that rules?
17 ;;; NMAP FIN Stealth scan
chain=forward action=add-src-to-address-list
tcp-flags=fin,!syn,!rst,!psh,!ack,!urg src-address-list=!BW
address-list=Bees address-list-timeout=1d protocol=tcp
18 ;;; SYN/FIN scan
chain=forward action=add-src-to-address-list tcp-flags=fin,syn
src-address-list=!BW address-list=Bees address-list-timeout=1d
protocol=tcp
19 ;;; SYN/RST scan
chain=forward action=add-src-to-address-list tcp-flags=syn,rst
protocol=tcp
20 ;;; FIN/PSH/URG scan
tcp-flags=fin,psh,urg,!syn,!rst,!ack src-address-list=!BW
21 ;;; ALL/ALL scan
tcp-flags=fin,syn,rst,psh,ack,urg src-address-list=!BW address-list=Bees
22 ;;; NMAP NULL scan
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg src-address-list=!BW
those rules do not need connection tracking…
Here is the reply I got from support this morning…
Connection tracking is necessary for almost all (including PSD) firewall
options.
Scott
Chupaka
November 14, 2007, 3:01pm
7
PSD is internal mechanism for scan detection. you do not use it in your rules.
Actually I only posted a portion of the rules that applied to this post, obviously I missed one
So the PSD mechanism requires conn tracking but the rules I posted here do not… does that sound correct? Would make more sense to me if that were the case.
Scott
Chupaka
November 14, 2007, 3:14pm
9
yes, your rules do not use internal firewall PSD
correct. anything where it’s looking at more than just tcp flags or things that encompass only single packets should be okay without conntrack. (someone correct me if im wrong …)
Sam
