Port scanner shows port 53 open although blocked in firewall
Hi all,
I’m undertaking some security improvements on my Mikrotik router and I’m running a port scanning software from a remote host to see what ports are open from outside. Although I drop port 53 udp/tcp, the scanner shows that the port is open. How come? Thank you.
Yes, I have enabled “Allow Remote Requests” in DNS, but it shouldn’t matter
/ip firewall filter add action=drop chain=input comment="Deny DNS from Outside" dst-port=53 in-interface=WAN protocol=tcp
/ip firewall filter add action=drop chain=forward comment="Deny DNS from Outside" dst-port=53 in-interface=WAN protocol=udp
/ip firewall filter add action=drop chain=input comment="Deny DNS from Outside" dst-port=53 in-interface=WAN protocol=udp
/ip firewall filter add action=drop chain=forward comment="Deny DNS from Outside" dst-port=53 in-interface=WAN protocol=tcp
Are you sure you are making your scan from the interface called WAN?
Post the complete export of the firewall and the output of /interface print. Order of rules matters, so your “drop the DNS requests” rule may be shadowed by some permissive one. Check my automatic signature below regarding anonymisation.
Solved. Had an accept rule above that couldn’t find. Thank you.
And in there lies the magic in posting “full configs” when asking help, due to COVID-19 crystal ball manufacturing has been closed down
