hi all,
i’m using mikrotik and all is fine with me, but i have a tiny problem that i can’t access my router remotely with winbox and telnet.
Please help me
Probably you have firewall rule in chain=input that is blocking access to your router.
Thanks for your Reply, but i want a solution for that problem, Please help me
How can I suggest your solution, if I do not know anything about the router configuration ?
You need to find the way to access this router locally with monitor and keyboard or serial COM cable and check what is wrong with that router.
Thanks my friend,
But i want to ask you how can i use Serial cable to log in to my router
Hai fren
i hope this link will help you how to connect to RB when Ehternet1 interface is disabled ?
regards
Hasbullah.com
Use this guide to get access to router with COM cable,
http://wiki.mikrotik.com/wiki/First_time_startup
Find computer that has COM port,
use HyperTerminal on Windows or Minicom on Linux.
