Port speed limiting and DHCP
Hello:
We are in the process of trying to figure out how to use the Queue for port speed limiting. We have applications that one port (typically port 1) will be used as the WAN ethernet master and will have the static public ip on it. We want to have all of the ports isolated from each other, and have DHCP working on all 23 ports on a private LAN. However when we try to set this up. The Port Speed control in the Queue does not do anything or the config seems to be wiped out. Basically our goal is to have 3 clustered switches with one being the master control router/switch.
Any thoughts?
Thanks!
