Hi
I’ve recently got handed a Mikrotik RouterBOARD 750 and now need to install it into our network.
We have a separate VLAN for our voice systems throughout our network. Our switches handle the tagged traffic just fine… Up to a point… They don’t do inter-VLAN routing on their own and need a L3 router to do it. Now I have managed to get the Mikrotik to handle inter-VLAN routing without an issue, the issue I am having now is that the Mikrotik is supposed to replace our current L3 switch (Which is failing) and I’m not exactly sure on the terminology changes.
Currently, the PBX is on the L3 switch and has the 2 ports it uses (Incoming from external fibre and then the other leads to the physical PBX) set with a “PVID” that is the same as a VLAN tag. From what I understand, it is not VLAN aware which is why it was done this way.
I feel like I should add what I want my configuration to look like at the end.
Mikrotik Port 1 - Connected to fibre internet data connection
Mikrotik Port 2 - Connected to internal network for internet, inter-VLAN routing and DHCP Relay for all VLANs.
Mikrotik Port 3 - Nothing connected
Mikrotik Port 4 - Connected to fibre voice data connection (VLAN8?)
Mikrotik Port 5 - Connected to PBX (VLAN8?)
How do I do the same on a Mikrotik?
