Hi all,
I’m Now using MT, all is fine, but recently when i began to use caching i have a problem with my log file, i have a message tell me that:
Web proxy error: Port xxxx already in use
I tried many times to change that port, but the same message is appeared, The ports which i use are ( 8080, 8000, 3128, 3127,…).
Please HELP…
Confirm the following;
- RouterOS version?
- That you are trying to use the internal web proxy?
If (2) is correctly assumed then the web proxy can only listen on one port and not multiple ports as your trying to do.
I want to use an internal webproxy, but no port is valid, please give me the best way to do that
Can you please tell me does 2.9.6 version supports Proxylizer,
I am facing problem "Port already in use " while setting web proxy
