Portforwarding on RB750G
Hi
New here so be kind =)
I looked up for portforwarding on my RB750G and this worked → /ip firewall nat add chain=dstnat dst-address=69.69.69.69 protocol=tcp dst-port=5900 \action=dst-nat to-addresses=192.168.1.101 to-ports=5900
At dst-adress:69.69.69.69, why do I need my public ip adress, isn´t enought with the routers 192.168.88.1 adress?
Everytime my ip adress changes I need to change my portforwarding in the router, right?
Is there something I can do about this, so I don´t need to change portforwarding everytime I get a new ip adress?
use dyndns type service to update your dynamic ip address via a Mikrotik script. Works well.
Hi !
You do not need to specify dst-address !!
add action=dst-nat chain=dstnat dst-port=18080 protocol=tcp to-addresses=192.168.5.100 to-ports=8080
Try !!
Thanks =)
Now it works even better
Cheers
