Portforwarding Site2Site VPN
Hi everybody!
I’ve a short question:
I’ve connected to sites via Site2Site VPN.
SiteA: 10.1.2.0/24
Webserver: 10.1.2.1/24
SiteB: 10.1.3.0/24
PublicIP: 8.8.8.8
How can I forward the traffic from the SiteB public IP (8.8.8.:sunglasses: to the Webserver?
I’ve already created a NAT rule, but the problem is, that the packet comes with a public IP and not the SiteBs Mikrotiks internal IP and so the traffic will be routed via the default route on SiteA-Router.
Thank you,
br Martin
Port forwarding
Nat Rule
chain=dstnat
action=device internal port
protocol=tcp
in-interface=internet gateway
dst-port=device external port
you need to specify a port for your server or device and its ip
and point it to that port and gateway on the router
also 8.8.8.8 is google dns, use a different ip
thank you for your post.
The solution is:
Create port forwarding rule for the service. And a masquerading rule with dst address of the web server on SiteA, which is placed before the nat rule.
br Martin
