preto
April 12, 2012, 7:10am
1
I have a problem with the NAT / Portforwarding -Issue on a RB700.
I want forward publicIP/48443 to an internal webserver: 192.168.x.x./8443
This configuration doesent work.
Here my config:
Filter:
4 ;;; NAT Ports
chain=forward action=accept protocol=tcp in-interface=pppoe-airlink
dst-port=8443
NAT:
2 ;;; ips webfront
chain=dstnat action=dst-nat to-addresses=192.168.112.212 to-ports=8443
protocol=tcp dst-port=8443
3 ;;; masquerading
chain=srcnat action=masquerade out-interface=pppoe-airlink
If I change the dst. port number to 8443 (the same port as internal) it works. but it is not that what i want…
Can you help me?
Thanks!
Try specifying in-interface or public IP address as dst-address for “;;; ips webfront” rule.
preto
April 12, 2012, 8:19am
3
Sorry no success.
Maybe it helps if I send the complete firewall config:
filter:
0 chain=input action=log log-prefix="inp_"
1 chain=forward action=log log-prefix=""
2 ;;; allow already established connections
chain=forward action=accept connection-state=established
3 ;;; Accept anything from inside
chain=forward action=accept in-interface=ether3-lan
4 ;;; NAT Ports
dst-port=48443
5 ;;; NAT Ports
dst-port=43389
6 ;;; NAT Ports
dst-port=4822
7 ;;; Drop invalid connections
chain=forward action=drop connection-state=invalid
8 ;;; allow releates connections
chain=forward action=accept connection-state=related
9 ;;; Deny anything else
10 ;;; Drop invalid connections
chain=input action=drop connection-state=invalid src-address-type=""
11 ;;; Accept anything from inside
chain=input action=accept in-interface=ether3-lan
12 ;;; Allow established connections
chain=input action=accept connection-state=established
13 ;;; Allow ICMP
chain=input action=accept protocol=icmp
14 ;;; Deny anything else
NAT:
0 ;;; naboo ssh
chain=dstnat action=dst-nat to-addresses=192.168.112.2 to-ports=22 protocol=tcp dst-port=4822
1 ;;; ips rdp
chain=dstnat action=dst-nat to-addresses=192.168.112.212 to-ports=3389 protocol=tcp dst-port=43389
2 ;;; ips webfront
chain=dstnat action=dst-nat to-addresses=192.168.112.212 to-ports=8443 protocol=tcp in-interface=pppoe-airlink dst-port=48443
3 ;;; masquerading
Maybe there are any mistakes here…
Take a look at http://wiki.mikrotik.com/wiki/Packet_Flow . “Destination NAT” is before “Filter Forward”, so you need to accept dst-port=8443 not dst-port=48443 traffic.
preto
April 12, 2012, 9:47am
5
This was the solution. Many thanks!
Is there anything else to specify on the forward rule, so that the dst-port ist only available via NAT and not direct to the wan-interface…
tinka
December 2, 2012, 8:14pm
6
Take a look at > http://wiki.mikrotik.com/wiki/Packet_Flow > . “Destination NAT” is before “Filter Forward”, so you need to accept dst-port=8443 not dst-port=48443 traffic.
and that just solved my problem. Thanks. For some odd reason having the firewall rules as the first tab and NAT as the second one made me assume that it was first “Filter Forward” and then “Destination NAT”.
