Portforwarding with pppoe won't work
Hi there,
I am currently a little bit confused, because I the portforwarding with the pppoe connection won’t work.
It’s not my first Routerboard where I do this but the first with pppoe.
So what I already have done is to setup the default masquerade rule for die outinterface and place it as first.
If I add a second dst-nat rule the connection stops working.
Any idea for that?
Thanks!
Gesendet von meinem HUAWEI GRA-L09 mit Tapatalk
It doesn’t matter what exacly connection you use. Firewall manipulate the IP packets flows. Paste here your “ip firewall nat export”
Here are the current export from nat:
# nov/10/2017 06:29:34 by RouterOS 6.41rc52
# software id = R3IZ-BBCZ
# model = 2011UiAS
# serial number = 763107FDC325
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
    pppoe-out1
add action=dst-nat chain=dstnat disabled=yes dst-port=443 log=yes protocol=tcp \
    to-addresses=172.20.0.100 to-ports=443
currently i disabled the second rule.
here are the filter rules:
# nov/10/2017 06:31:16 by RouterOS 6.41rc52
# model = 2011UiAS
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    pppoe-out1 protocol=tcp
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=pppoe-out1
just for information the ipadress assigned on the pppoe connection is dynamical.
Just now i made a second try, it looks like the problem only exist’s with port 443.
In dstnat chain try assign in-interface and your current IP address. Other settings seems fine.
Yes, adding the in-interface fixed the problem to arrive https websites from the lokal subnet. But now i gonna stuck, i can’t arrive my lokal website trough the external ip-address. Any idea how to fix that?
Hairpin NAT
http://forum.mikrotik.com/t/hairpin-hat-not-working/113597/16
ip firewall nat
add action=dst-nat chain=dstnat dst-address=“your global IP” dst-port=443 in-interface=“LAN interface for your web server”
protocol=tcp src-address=“your LAN” to-addresses=172.20.0.100 to-ports=443
add action=masquerade chain=srcnat dst-address=172.20.0.100 dst-port=443 out-interface=“LAN interface for your web server” protocol=tcp src-address=“your LAN”
