Ports configuration
Hello:
I’m using a 750 to connect an accelerograph (using RTPD protocol) with a Linux machine running the RTPD service. I need help to configure the router so I can have connection in both directions. In the router I have opened the required port 2543 UDP and also TCP for the transfer of the data. It seems that it is working but only in one direction. The Linux machine sees the DAS and map the unit; however when it comes the time to send the acknowledgment message back, it seems that it is not reaching the DAS and therefore the data cannot flow.
How can I configure the router to allow messages flow in either direction to an specific port in the DAS and the linux box? The linux box has an IP that is not in the same subnet than the router and the DAS
Regards
Antonio
