House Config:
# 2026-03-30 17:49:30 by RouterOS 7.22.1
# software id = SDS3-1ITZ
# model = C53UiG+5HPaxD2HPaxD
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=yes
/interface wireguard
add listen-port=51820 mtu=1420 name=wg-iphone
add listen-port=55730 mtu=1420 name=wg-nordvpn
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlan20 vlan-id=20
add interface=bridge name=vlan30 vlan-id=30
add interface=bridge name=vlan40 vlan-id=40
add interface=bridge name=vlan50 vlan-id=50
add interface=bridge name=vlan60 vlan-id=60
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge comment="Trusted WiFi VLAN20" disabled=no name=dp_VLAN20 \
vlan-id=20
add bridge=bridge client-isolation=yes comment="IoT VLAN30" disabled=no name=\
dp_VLAN30 vlan-id=30
add bridge=bridge client-isolation=yes comment="Isolated VLAN50" disabled=no \
name=dp_VLAN50 vlan-id=50
add bridge=bridge comment="Guest WiFi VLAN60" disabled=no name=dp_VLAN60 \
vlan-id=60
add bridge=bridge comment="No VLAN tagging" disabled=no name=dp_plain
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-trusted
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-iot
add authentication-types=wpa2-psk disabled=no name=sec-untrusted
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-guest
/interface wifi configuration
add channel.width=20mhz country="United Kingdom" datapath=dp_VLAN20 disabled=\
no name=cfg-trusted security=sec-trusted ssid="TJC"
add channel.width=20mhz country="United Kingdom" datapath=dp_VLAN30 \
datapath.client-isolation=yes disabled=no name=cfg-iot security=sec-iot \
ssid="DCG"
add channel.width=20mhz country="United Kingdom" datapath=dp_VLAN50 \
datapath.client-isolation=no disabled=no name=cfg-untrusted security=\
sec-untrusted ssid="MEC"
add channel.width=20mhz country="United Kingdom" datapath=dp_VLAN60 disabled=\
no name=cfg-guest security=sec-guest ssid="RGA"
add channel.width=20/40mhz country="United Kingdom" datapath=dp_VLAN20 \
disabled=no name=cfg-trusted-24 security=sec-trusted ssid=\
"TJC"
add name=pool10 ranges=10.0.10.10-10.0.10.200
add name=pool20 ranges=10.0.20.10-10.0.20.200
add name=pool30 ranges=10.0.30.10-10.0.30.200
add name=pool40 ranges=10.0.40.10-10.0.40.200
add name=pool50 ranges=10.0.50.10-10.0.50.200
add name=pool60 ranges=10.0.60.10-10.0.60.200
add add-arp=yes address-pool=pool10 comment=Infra interface=vlan10 \
lease-script=dhcp-dns lease-time=20m name=dhcp10
add add-arp=yes address-pool=pool20 comment="Trusted WiFi" interface=vlan20 \
lease-script=dhcp-dns lease-time=20m name=dhcp20
add add-arp=yes address-pool=pool30 comment=IoT interface=vlan30 \
lease-script=dhcp-dns lease-time=20m name=dhcp30
add address-pool=pool40 comment="NAS / Wired Guest" interface=vlan40 \
lease-script=dhcp-dns lease-time=20m name=dhcp40
add address-pool=pool60 comment="Guest WiFi" interface=vlan60 lease-script=\
dhcp-dns lease-time=20m name=dhcp60
add address-pool=pool50 interface=vlan50 lease-time=1h name=dhcp50
/routing table
add fib name=nordvpn
add fib name=to-nordvpn
add bridge=bridge comment="Access port VLAN40" frame-types=\
admit-only-untagged-and-priority-tagged interface=ether2 \
internal-path-cost=10 path-cost=10 pvid=40
add bridge=bridge comment="Trunk to Garage" frame-types=\
admit-only-vlan-tagged interface=ether3 internal-path-cost=10 path-cost=\
10
add bridge=bridge comment="Access port VLAN10" frame-types=\
admit-only-untagged-and-priority-tagged interface=ether5 \
internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge comment="Trunk to Loft" frame-types=admit-only-vlan-tagged \
interface=ether4
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge comment="Trusted WiFi VLAN" tagged=bridge,ether4,ether3 \
vlan-ids=20
add bridge=bridge comment="IoT VLAN" tagged=bridge,ether4,ether3 vlan-ids=30
add bridge=bridge comment="Isolated VLAN" tagged=bridge,ether3,ether4 \
vlan-ids=50
add bridge=bridge comment="Guest WiFi VLAN" tagged=bridge,ether3,ether4 \
vlan-ids=60
add bridge=bridge comment="NAS / Wired Guest VLAN" tagged=\
bridge,ether2,ether4 vlan-ids=40
add bridge=bridge comment="Infra VLAN" tagged=bridge,ether3,ether4 untagged=\
ether5 vlan-ids=10
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
all wan-interface-list=all
add interface=vlan10 list=LAN
add interface=vlan20 list=LAN
add interface=vlan40 list=LAN
add interface=vlan60 list=LAN
/interface ovpn-server server
add mac-address=xx:xx:xx:xx:xx:xx name=ovpn-server1
/interface wifi cap
set caps-man-addresses=10.0.10.1 discovery-interfaces=bridge enabled=yes
/interface wifi capsman
set enabled=yes interfaces=bridge,vlan10,lo
/interface wifi provisioning
add action=create-dynamic-enabled comment=normal disabled=no \
master-configuration=cfg-trusted name-format=Wifi-%I \
slave-configurations=cfg-untrusted,cfg-guest,cfg-iot
add action=create-enabled disabled=yes master-configuration=cfg-trusted-24 \
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-allowed-address=0.0.0.0/0 \
endpoint-address=pl128.nordvpn.com endpoint-port=51820 interface=\
wg-nordvpn name=peer1 persistent-keepalive=1m public-key=\
"kjAOzXQRVGpmQdqE2zPsITH8QHmFK83AAPktqWed9wM="
add allowed-address=10.44.0.2/32 client-allowed-address=::/0 interface=\
wg-iphone name=iPhone public-key=\
"L+V9o0fNYkMVKNqsX7spBzD/9oSvxM/C7ZCZX1jLO3Q=" responder=yes
add allowed-address=10.44.0.3/32 client-address=10.44.0.3/32 \
client-allowed-address=::/0 client-dns=10.0.40.1 client-endpoint=\
wg.<my domain> client-keepalive=25s client-listen-port=51820 interface=\
wg-iphone name=iPad public-key=\
"cbhUX7YJt6yydsJWKfI4PQBaFHqlIIME40DF1lYmUGw="
add address=10.0.20.1/24 interface=vlan20 network=10.0.20.0
add address=10.0.30.1/24 interface=vlan30 network=10.0.30.0
add address=10.0.40.1/24 interface=vlan40 network=10.0.40.0
add address=10.0.60.1/24 interface=vlan60 network=10.0.60.0
add address=10.0.10.1/24 interface=vlan10 network=10.0.10.0
add address=10.5.0.2 interface=wg-nordvpn network=10.5.0.2
add address=10.0.70.1/24 interface=*58 network=10.0.70.0
add address=10.44.0.1/24 interface=wg-iphone network=10.44.0.0
add address=10.0.50.1/24 interface=vlan50 network=10.0.50.0
/ip dhcp-client
add comment=defconf interface=ether1 name=ether1
add address=10.0.10.0/24 comment=Management dns-server=10.0.10.1 domain=\
<my internal domain> gateway=10.0.10.1 netmask=24
add address=10.0.20.0/24 comment=Trusted dns-server=10.0.20.1 domain=\
<my internal domain> gateway=10.0.20.1 netmask=24
add address=10.0.30.0/24 comment=IoT dns-server=10.0.30.1 domain=<my internal domain> \
gateway=10.0.30.1 netmask=24
add address=10.0.40.0/24 comment=NAS domain=<my internal domain> gateway=10.0.40.1 \
netmask=24
add address=10.0.50.0/24 comment=Isolated dns-server=10.0.50.1 domain=\
<my internal domain> gateway=10.0.50.1 netmask=24
add address=10.0.60.0/24 comment=Guest domain=<my internal domain> gateway=10.0.60.1 \
netmask=24
set allow-remote-requests=yes servers=1.1.1.1
/ip firewall address-list
add address=173.245.48.0/20 list=CloudFlare
add address=103.21.244.0/22 list=CloudFlare
add address=103.22.200.0/22 list=CloudFlare
add address=103.31.4.0/22 list=CloudFlare
add address=141.101.64.0/18 list=CloudFlare
add address=108.162.192.0/18 list=CloudFlare
add address=190.93.240.0/20 list=CloudFlare
add address=188.114.96.0/20 list=CloudFlare
add address=197.234.240.0/22 list=CloudFlare
add address=198.41.128.0/17 list=CloudFlare
add address=162.158.0.0/15 list=CloudFlare
add address=104.16.0.0/13 list=CloudFlare
add address=104.24.0.0/14 list=CloudFlare
add address=172.64.0.0/13 list=CloudFlare
add address=131.0.72.0/22 list=CloudFlare
add action=accept chain=forward comment="Allow DNAT to internal servers" \
connection-nat-state=dstnat in-interface=ether1
add action=drop chain=input comment="INPUT: drop invalid" connection-state=\
invalid log=yes log-prefix="drop - "
# no interface
# no interface
add action=accept chain=input comment="TEMP: allow VLAN50 to router" \
in-interface=*10
add action=accept chain=input comment="INPUT: allow VLAN50 ping" disabled=yes \
in-interface=*10 protocol=icmp
add action=accept chain=input comment="INPUT: allow VLAN50 to router" \
disabled=yes in-interface=*10
add action=accept chain=input comment="INPUT: allow local CAPsMAN" disabled=\
yes dst-address=0.0.0.0/0 dst-port=5246,5247 protocol=udp src-address=\
0.0.0.0/0
add action=accept chain=forward comment="FW: VLAN40 -> VLAN10 (return)" \
in-interface=vlan40 out-interface=vlan10
"INPUT: allow CAPs / CAPsMAN from VLAN10" src-address=10.0.10.0/24
add action=accept chain=input comment="INPUT: accept established, related" \
add action=accept chain=input comment="INPUT: allow ICMP" protocol=icmp
add action=accept chain=input comment="Allow WireGuard" dst-port=51820 \
protocol=udp
add action=accept chain=forward comment="FW: Allow iPhone WG VLAN40" \
connection-nat-state="" dst-address=10.0.40.0/24 src-address=10.44.0.0/24
add action=drop chain=forward comment="FW: Block WG iPhone from other VLANs" \
log=yes log-prefix="drop - " src-address=10.44.0.0/24
add action=accept chain=forward comment="FW - JellyFin" dst-port=30013 \
in-interface=vlan20 log-prefix=TESTLOG- out-interface=vlan40 protocol=tcp
add action=accept chain=forward comment="FW - Infuse - iPhone" dst-address=\
10.0.40.11 dst-port=445 in-interface=vlan20 log-prefix=TESTLOG- \
out-interface=vlan40 protocol=tcp src-address=10.0.20.197
add action=accept chain=forward comment="FW - Infuse - iPad" dst-address=\
out-interface=vlan40 protocol=tcp src-address=10.0.20.199
"INPUT: allow management from VLAN10 (Infra)" in-interface=vlan10
add action=accept chain=input comment="INPUT: VLAN20 DNS/DHCP" dst-port=\
53,67,68 in-interface=vlan20 protocol=udp
add action=accept chain=input comment="IN: WG to DNS" dst-port=53 \
in-interface=wg-iphone protocol=udp
add action=accept chain=input comment="INPUT: VLAN30 DNS/DHCP only" dst-port=\
53,67,68 in-interface=vlan30 protocol=udp
add action=accept chain=input comment="INPUT: VLAN40 DNS/DHCP only" dst-port=\
53,67,68 in-interface=vlan40 protocol=udp
add action=accept chain=input comment="INPUT: VLAN50 DNS/DHCP only" disabled=\
yes dst-port=53,67,68 in-interface=*10 protocol=udp
add action=accept chain=input comment="INPUT: VLAN60 DNS/DHCP only" dst-port=\
53,67,68 in-interface=vlan60 protocol=udp
add action=accept chain=forward comment="IP Camera from Frigate" dst-address=\
10.0.30.192 src-address=10.0.40.11
add action=drop chain=input comment="INPUT: drop everything else from WAN" \
in-interface-list=WAN log=yes log-prefix="drop - "
add action=drop chain=input comment="INPUT: drop everything else" log=yes \
log-prefix="INPUT_Drop - "
add action=accept chain=forward comment="FW: VLAN50 -> NordVPN" disabled=yes \
in-interface=*10 out-interface=wg-nordvpn
add action=accept chain=forward comment="FW: NordVPN -> VLAN50 return" \
disabled=yes in-interface=wg-nordvpn out-interface=*10
add action=accept chain=forward comment="FW: allow DHCP OFFER to VLAN30" \
dst-port=68 out-interface=vlan30 protocol=udp
add action=accept chain=forward comment="FW: allow DHCP OFFER to VLAN40" \
dst-port=68 out-interface=vlan40 protocol=udp
add action=accept chain=forward comment="FORWARD: allow DHCP OFFER to VLAN60" \
dst-port=68 out-interface=vlan60 protocol=udp
add action=drop chain=forward comment="FORWARD: drop invalid" \
connection-state=invalid log=yes log-prefix="drop - "
"FORWARD: accept established, related" connection-state=\
established,related
add action=accept chain=forward comment="FORWARD: allow DHCP OFFER to VLAN20" \
dst-port=68 out-interface=vlan20 protocol=udp
add action=accept chain=forward comment="FORWARD: allow DHCP OFFER to VLAN50" \
disabled=yes dst-port=68 out-interface=*10 protocol=udp
add action=accept chain=forward comment="FORWARD: VLAN10 -> WAN" \
in-interface=vlan10 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN20 -> WAN" \
in-interface=vlan20 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN30 -> WAN" \
in-interface=vlan30 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN40 -> WAN" \
in-interface=vlan40 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN50 -> WAN" disabled=yes \
in-interface=*10 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN60 -> WAN" \
in-interface=vlan60 out-interface-list=WAN
add action=accept chain=forward comment="FORWARD: VLAN10 -> VLAN20 (admin)" \
in-interface=vlan10 out-interface=vlan20
add action=accept chain=forward comment="FORWARD: VLAN10 -> VLAN30 (admin)" \
in-interface=vlan10 out-interface=vlan30
add action=accept chain=forward comment="FORWARD: VLAN10 -> VLAN40 (admin)" \
in-interface=vlan10 log=yes out-interface=vlan40
add action=accept chain=forward comment="FORWARD: VLAN10 -> VLAN50 (admin)" \
disabled=yes in-interface=vlan10 out-interface=*10
add action=accept chain=forward comment="FORWARD: VLAN10 -> VLAN60 (admin)" \
in-interface=vlan10 out-interface=vlan60
"FORWARD: VLAN20 -> VLAN30 (trusted -> IoT)" in-interface=vlan20 \
add action=accept chain=forward comment="FORWARD: FamilyRoom TV to JellyFin" \
dst-address=10.0.40.11 dst-port=30013 protocol=tcp src-address=\
10.0.30.200
add action=drop chain=forward comment="FORWARD: block VLAN30 -> VLAN10" \
in-interface=vlan30 log=yes log-prefix="drop - " out-interface=vlan10
add action=drop chain=forward comment="FORWARD: block VLAN30 -> VLAN20" \
in-interface=vlan30 log=yes log-prefix="drop - " out-interface=vlan20
add action=drop chain=forward comment="FORWARD: block VLAN30 -> VLAN40" \
in-interface=vlan30 log=yes log-prefix="drop - " out-interface=vlan40
add action=drop chain=forward comment="FORWARD: block VLAN30 -> VLAN50" \
disabled=yes in-interface=vlan30 log=yes log-prefix="drop - " \
out-interface=*10
add action=drop chain=forward comment="FORWARD: block VLAN30 -> VLAN60" \
in-interface=vlan30 log=yes log-prefix="drop - " out-interface=vlan60
"FORWARD: block VLAN30 device-to-device" in-interface=vlan30 log=yes \
log-prefix="drop - " out-interface=vlan30
add action=drop chain=forward comment="FORWARD: block VLAN60 -> VLAN10" \
in-interface=vlan60 log=yes log-prefix="drop - " out-interface=vlan10
add action=drop chain=forward comment="FORWARD: block VLAN60 -> VLAN20" \
in-interface=vlan60 log=yes log-prefix="drop - " out-interface=vlan20
add action=drop chain=forward comment="FORWARD: block VLAN60 -> VLAN30" \
in-interface=vlan60 log=yes log-prefix="drop - " out-interface=vlan30
add action=drop chain=forward comment="FORWARD: block VLAN60 -> VLAN40" \
in-interface=vlan60 log=yes log-prefix="drop - " out-interface=vlan40
add action=drop chain=forward comment="FORWARD: block VLAN60 -> VLAN50" \
disabled=yes in-interface=vlan60 log=yes log-prefix="drop - " \
out-interface=*10
"FORWARD: block VLAN60 device-to-device" in-interface=vlan60 log=yes \
add action=drop chain=forward comment="FORWARD: block VLAN50 -> VLAN10" \
disabled=yes in-interface=*10 log=yes log-prefix="drop - " out-interface=\
vlan10
add action=drop chain=forward comment="FORWARD: block VLAN50 -> VLAN20" \
vlan20
add action=drop chain=forward comment="FORWARD: block VLAN50 -> VLAN30" \
vlan30
add action=drop chain=forward comment="FORWARD: block VLAN50 -> VLAN40" \
vlan40
add action=drop chain=forward comment="FORWARD: block VLAN50 -> VLAN60" \
vlan60
"FORWARD: block VLAN50 device-to-device" disabled=yes in-interface=*10 \
log=yes log-prefix="testdrop - " out-interface=*10
add action=drop chain=forward comment="FORWARD: drop everything else" log=yes \
log-prefix="DefaultDrop - "
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=to-nordvpn \
src-address=10.0.50.0/24
add action=dst-nat chain=dstnat comment="NAT: Crib Web Site" dst-port=443 \
in-interface=ether1 log=yes log-prefix=CribNAT protocol=tcp \
src-address-list=CloudFlare to-addresses=10.0.30.187 to-ports=443
add action=masquerade chain=srcnat comment=\
"NAT: NordVPN WireGuard masquerade" out-interface=wg-nordvpn
add action=masquerade chain=srcnat comment="NAT: iPhone WireGuard masquerade" \
out-interface=wg-iphone
add action=masquerade chain=srcnat comment="NAT: WAN masquerade" \
add action=redirect chain=dstnat dst-port=53 protocol=udp src-address=\
10.0.50.0/24 to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=tcp src-address=\
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip ipsec profile
add dst-address=0.0.0.0/0 gateway=wg-nordvpn routing-table=nordvpn
add dst-address=10.0.40.0/24 gateway=wg-iphone
add dst-address=0.0.0.0/0 gateway=wg-nordvpn routing-table=to-nordvpn
/ip service
set ftp disabled=yes
set ssh address=10.0.10.0/24
set telnet disabled=yes
set www disabled=yes
set winbox address=10.0.10.0/24
set api disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 dhcp-client
add interface=ether1 pool-name=ee-ipv6 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
established,related,untracked
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system identity
set name=House
/system logging
add topics=caps
add disabled=yes topics=dhcp
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=1.1.1.1
/system scheduler
add interval=30s name=sync-dns on-event=sync-dns policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2026-03-21 start-time=20:20:33
add comment="Dynamic DNS CLoudflare" interval=5m name=Cloudflare_DNS \
on-event=Dyn-DNS policy=\
start-date=2026-03-27 start-time=15:27:48
/tool bandwidth-server
set enabled=no
/tool traffic-monitor
add interface=ether5 name=tmon1
