Possible bug found in 5Mhz scan. Pls confirm!
When performing wireless scan in 5Mhz mode the scan does pick up 20Mhz channels.
The scan is run for at least 10 mins so plenty of time to run through all channels.
rb433AH with v5.9 fw updated.
I already made report to MT.
Can anybody repeat this and see if the result is the same?
Make sure the wireless scanlist is empty to make sure radio scans the whole band.
Scan in 20Mhz mode picks up 20Mhz channels
Scan in 10Mhz mode picks up 10Mhz channels
Scan in 5Mhz mode picks up 20Mhz channels
If no 5Mhz channels are around the scan should stay empty.
Hi Rudy …
I did this test using a spare R52nM and worked ok (e.g. no 20MHz APs detected on 5MHz channels). May be with another card this can be possible. I left card at “A mode” only. And channel plan for my country.
Regards;
