One of my coleges disabled the Ethernet port on which is started PPPoE server. After that he couldn’t enable it again. He said that the active pppoe connections doesn’t disconnect. After reboot he enabled the interface and everything was working again. I don’t have sup-output.
I saw the same thing with 2.8.15 and 2.8.17, but I found that if you go into the pppoe connection and select dial on demand and apply it, then turn it back off the pppoe will start running again.
Ult
Sounds like a bug, we will check it.
John
