Hi guys,
I have several years using hotspots in MT with SSL certificates in hotspot service. However, now I realised that the following attributes donot have https
- link-logout
- link-status
But link-login-only attribute has the correct prefix https.
Of course, I can detect if there is a SSL certificate using the ssl-login attribute (with yes value) and, then change manually the attribute http to https. Even though, I think ROS must be done automatically.
Is this a correct behaoviour for you?
Best regards,
Santiago
