I stumbled across a bug concerning eoip tunnels. I just cannot remove it.
There was a mention of such bug earlier in this forum: http://forum.mikrotik.com/t/some-ugly-bug-while-removing-eoip-tunnels/12301/1 however, the proposed solution (disable than remove) does not work.
Hardware in question here is a dual Xeon, with MT v.5.18.
Here is how it goes:
/interface eoip> pri
0 name="eoip-tunnel1" mtu=1500 l2mtu=65535 mac-address=00:00:00:00:00:00
arp=enabled local-address=0.0.0.0 remote-address=0.0.0.0 tunnel-id=0
/interface eoip> remo 0
failed to remove EoIP tunnel
The same is if I try to modify it, disable it or whatever I try to do with it … Like a ghost.
Reboot and retry doesn’t help. Still get the same.
Anyone else came up on this? Any ideas?
Regards to all!
