Possible connection tracking problem??
Greetings,
When I enable logging for packets that are dropped in the input chain, I get flooded with entries that look like this:
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (SYN,ACK), 72.246.103.18:80->75.54.4.45:2897, len 48
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (RST), 66.135.217.231:80->75.54.4.45:3521, len 40
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (SYN,ACK), 68.180.207.182:80->75.54.4.45:3641, len 44
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (SYN,ACK), 68.180.207.182:80->75.54.4.45:3643, len 44
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (SYN,ACK), 72.247.242.178:80->75.54.4.45:1378, len 48
input: in:Public DSL out:(none), src-mac 00:0f:cc:89:18:24, proto TCP (SYN,ACK), 68.180.195.221:80->75.54.4.45:3639, len 48
These appear to be responses from external servers to HTTP requests made by people on our back network.
As far as I understand, these responses should be processed by the FORWARD and not the INPUT chain. It almost seems to me like our RouterBoard is not realizing that these responses are related to a SNAT’d HTTP request.
Any suggestions for troubleshooting this?
I don’t see a problem. Most of those are probably looking for an open relay email server to spam through. There are some among those that are really bad people, looking only to make your life very uncomfortable. Those are hackers and spammers. They should be dropped. I would not waste the log storage tho and remove the logging.
SurferTim,
I don’t interpret the logs that way. Those are not people scanning for open SMTP relays. That would be traffic destined to port 25. This is response traffic coming back from legitimate web servers (i.e. google, yahoo, akamai, etc) that is hitting the INPUT instead of FORWARD chain.
I should have looked closer. How do you have the log entry setup? Did you put a log action just before the “chain=input action=drop”?
Is anyone on your net reporting weird “page cannot be displayed” errors or the like?
It does seem like HTTP connections are occasionally being dropped (i.e. sometimes I have to hit reload to get a web page up). I’m not 100% sure that this is due to the FW and not “life on the net”.
The log action that generated those was the second to last line of the input chain. The last line is the drop rule.
BTW, I also tried expanding out the number of IPs used for SNAT and it didn’t seem to make a difference.
BTW, SYN/ACK is what my tarpit setting returns to a potential intruder. Maybe someone is going somewhere they are not supposed to be? Maybe they are getting tarpitted? But why to the input chain?
ADD: Check this out.
http://en.wikipedia.org/wiki/Portscanning
Look a few paragraphs down under the heading “SYN scanning”.
I should try and do some after-hours testing when people aren’t on the network, but I’m pretty sure that I’ve even seen my own HTTP traffic appear in these rules before. It really seems like they are HTTP response packets…
The only consolation is they all are “wait a second” packets from what I can see. And why to the input? I can’t see why they would go there. Do you have any firewall rules that would put them there?
you should try filter stoping this, because its very danger for you’re MikrOTik, and you should be more carefuly when you work in public interface..:smiley::D;
Hi alternativi-boy
They are being dropped. He is concerned that maybe they should NOT be dropped.
did you try to increase timeouts in connection tracking?
they are being dropped because the NAT table no longer knows them. Thats why they hit the input chain because they are no longer in NAT. Most of the time this is normal if they are FIN or RST type.
ChangeIP – thank you for expressing more clearly than I was able to exactly what I believe the problem is.
As these are SYN,ACK packets, I believe that these should be going through and forwarded and that the MT is dropping them from the NAT table.
My connection tracking parameters are:
TCP syn/received: 00:00:05
TCP established: 01:00:00
UDP stream timeout: 00:03:00
Generic timeout: 00:10:00
everything else: 00:00:010
TCP syncookies are disabled. Should I be changing any of these to higher values??
here is mine, can’t remember if these are defaults or not:
[xxx@xxx] ip firewall connection tracking> print
enabled: yes
tcp-syn-sent-timeout: 10s
tcp-syn-received-timeout: 5s
tcp-established-timeout: 4h ← modified for sure.
tcp-fin-wait-timeout: 10s
tcp-close-wait-timeout: 10s
tcp-last-ack-timeout: 10s
tcp-time-wait-timeout: 10s
tcp-close-timeout: 10s
udp-timeout: 10s
udp-stream-timeout: 1m
icmp-timeout: 10s
generic-timeout: 10m
tcp-syncookie: yes
I was poking around some of the MT documentation and they wrote:
tcp-syn-received-timeout (time; default: 1m) - maximal amount of time connection tracking entry will survive after having seen a matching connection request (SYN)
tcp-syn-sent-timeout (time; default: 1m) - maximal amount of time connection tracking entry will survive after having seen a connection request (SYN) from connection initiator
I upped these timeouts to 1M from my 5S and this seems to have cut down the amount of SYN,ACK’s that I have received.
I’m still receiving a fair number of ACK,FIN RST and ACK,FIN,PSH responses from web servers. My guess is that this is also timeout related. I found this information about ACK,FIN,PSH
Here’s what’s happening:
TCP 3 packet handshake takes place
Client issues a data request
Client issues a FIN/ACK since its done transmitting info
Netfilter drops the state time out to 60 seconds
Server starts transmitting data back to the client
More than 60 seconds goes by
Netfilter removes the state entry
Server can never complete the data transfer and continually tries to
issue a FIN/ACK to close the connection
Netfilter drops all FIN/ACK’s because the state table entry is gone
I reported this problem back in 2000 and the time out was increased to
120 seconds. At some point a few years back the time out was dropped
back down again causing the problem you are seeing.
I was doing some more digging around and found this:
Timeouts
Something to note is that timeouts are reset to the maximum each time a connection sees traffic. Timeouts are set in /usr/src/linux/net/ipv4/netfilter/ip_conntrack_proto_tcp.c at compile time. Here is the relevant section of code:
static unsigned long tcp_timeouts
= { 30 MINS, /* TCP_CONNTRACK_NONE, /
5 DAYS, /
TCP_CONNTRACK_ESTABLISHED, /
2 MINS, /
TCP_CONNTRACK_SYN_SENT, /
60 SECS, /
TCP_CONNTRACK_SYN_RECV, /
2 MINS, /
TCP_CONNTRACK_FIN_WAIT, /
2 MINS, /
TCP_CONNTRACK_TIME_WAIT, /
10 SECS, /
TCP_CONNTRACK_CLOSE, /
60 SECS, /
TCP_CONNTRACK_CLOSE_WAIT, /
30 SECS, /
TCP_CONNTRACK_LAST_ACK, /
2 MINS, /
TCP_CONNTRACK_LISTEN, */
There is no absolute timeout for a connection.
I wonder if the MT default timeouts are too aggressive (i.e. short)?
Are you using web-proxy?
May sound basic, but it’s usually the obvious which is overlooked…
We aren’t doing any web proxying (i.e. the MT neither serves nor makes use of any proxy servers)…
I just upgraded from 2.9.51 to 3.14rc1. I noticed now RST packets are dropped where they were not before. Is there any reason a single RST packet is dropped and not accepted as closing the connection on 3.x ?
last two months or so we started to see strange problem on our network. Some sites as youtube were sporadically not fully loaded, especially in the case where the site used off-site .CSS file storage. We ended up with content loaded, but without CSS it was not fully functional.
Apart from MT unreliable DNS (and yes, we still consider it being unreliable, so we don’t point our subnodes to our main router anymore), we are recently still observing:
  1. occassional “can’t display the page”. When you hit reload, it is loaded …
  2. rather high “invalid connection” traffic. Those are mainly of type (ACK, FIN), (ACK, RST, FIN), (RST), (ACK, FIN, PSH)
Our main router conntrack setting is:
enabled: yes
tcp-syn-sent-timeout: 5s
tcp-established-timeout: 1d
udp-timeout: 10s
udp-stream-timeout: 3m
icmp-timeout: 10s
tcp-syncookie: no
max-entries: 524288
total-entries: 7445
-pekr-
I am seeing this as well. Exact same settings between 2.9 and 3.x started dropping TONs more packets. I had to increase the initial timeouts to almost 20-30s to get them to slow down. I have a feeling some packets aren’t making it into the connection tracking so the other end has to retransmit (after 10-20s). I will run some packet sniffs to confirm.
