Possible misconfiguration of L2tp/ipsec roadwarrior
I Use this config to view camera connected to MT at home network from remote vpn client.
It works but i would like to resolve following things:
  • Now the home network and vpn tunnel are on the same subnet , and i have to use proxy-arp would it be better to have different subnet and if yes how can i change my config?
  • Port flapping every 5mins on port that has camera connected
# RouterOS 6.42.12
add admin-mac=B8:69:F4:8E:04:17 arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=hap_wpa \
    supplicant-identity="" wpa-pre-shared-key=wifipass \
    wpa2-pre-shared-key=wifipass
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=\
    20/40mhz-Ce country=belgium disabled=no distance=indoors frequency=auto \
    frequency-mode=regulatory-domain mode=ap-bridge security-profile=hap_wpa \
    ssid=Hap tx-power=15 tx-power-mode=all-rates-fixed wireless-protocol=\
    802.11 wps-mode=disabled
add name=dhcp ranges=10.0.0.10-10.0.0.99
add name=vpn ranges=10.0.0.200-10.0.0.220
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=10.0.0.1 remote-address=vpn
/interface l2tp-server server
set enabled=yes ipsec-secret=vpnsecret use-ipsec=yes
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1
set allow-remote-requests=yes
/ip dns static
add address=10.0.0.1 name=router.lan
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ip service
set telnet address=10.0.0.0/24 disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/24
set ssh address=10.0.0.0/24
set api address=10.0.0.0/24
set winbox address=10.0.0.0/24
set api-ssl address=10.0.0.0/24
/ppp secret
add name=vpn password=vpnpass service=l2tp
/system clock
set time-zone-name=Europe/Brussels
/system package update
set channel=long-term
/tool graphing resource
add allow-address=10.0.0.0/24
/tool mac-server
/tool mac-server mac-winbox
Anyone?
Is there noone that can take a look at my config and give some advice?
